Tie down advice for C-5
http://www.awdirect.com/awdirect/fin...fm?itemid=8979
(not sure if any vendors carry this, so hope I'm not stepping on anyone's toes with this, but I haven't seen these anywhere else)
I hook my tow straps in a pattern like this:
X
X
With the car sitting the middle of the two X's. The strap that hooks behind the LF wheel, goes forward under the car to the D-ring on the RF side of the trailer. Strap that goes behind the RF wheel goes foward to the D-ring on the LF side of the trailer. Strap that hooks in front of the LR wheel goes aft to the D-ring on the RR of the trailer. And the strap that goes in front of the RR wheel goes aft to the D-ring at the RR of the trailer.
Hope that helps.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
X
X
Hope that helps.
If you are looking at 3000lb straps, make sure that is not just the max limit, but the load poundage.
I use 10k straps on mine (4, with over axle straps) and wouldn't dare touch anything less while towing. Even the 10k straps can break if something goes wrong. Most places sell them by the max limit, so make sure you get ones at 10k or higher. The lesser ones are not rated for auto tie downs...
Best of luck!
Jim Kay
How many inches/feet ahead and behind your car did you have your D-rings? I am concerned with getting the proper angle on straps so that they won't rub front or rear fascia.
Did you have any issues with straps chafing on each other at the X point?
I use four 5000lbs straps ( specificly for race cars) got them from Northern Tool.
When I tie down my car I cross X the straps, right front D hook in the trailer floor to the T hook in left front jacking hole in the car frame. And so forth for the other straps.
The only issue I have found is where the car is on the trailer as for weight distribution. I also run 4 pounds less pressure in the front two trailer tires then the rear two trailer tires. Makes for a much more stable ride and tow.
What's the distance from the front of your car to the front D-rings?
I think more importantly is the car placement over the wheels of the trailer
Here is a pic just after loading and a trip to Lowes Motor Speedway.
All,
Thanks for the clarification. Been awhile since I bought my straps. I am confident my straps are 3000 working load and something like 10k max load. I should have been more specific on that.
When on my 18' Brimar trailer, the D-rings are about a foot in front of the front bumper on the front, and about even with the rear of the car in the back. This would be harder on an enclosed trailer since you can't get under the car, but on my open trailer, the car is up off the ground and I can easily reach the D-rings from the front and the rear without crawling in the mud.
When hooking my car up on the open air, I set the strap on the trailer in front of the RF tire, reach around the tire and grab the T-hook and hook in behind the RF tire, then grab the clip on the strap and walk it around the front of the trailer to the LF D-ring. Pretty easy.
Do you have to hook the T-hooks and straps to the frame before the car is in the trailer and then somehow drag the car in the trailer with the straps already hooked up?
I drive the car onto the trailer. No straps attached.
The t-hook on the end of the strap. I lay on the trailer floor and toss it under the car to the side I that I will hook the t-hook into. Then I go to the side of the car and reach under the car and feel, sorry to tight to look, for the hook - grab it and put it in the frame hole. I do this for all four hooks and straps then slowly tighten the ratches up.
Now getting out of the car after driving it in the trailer is another challange.
I have a coupe so I take the top off and put it in the back of the car. Car doors dont open so leave your windows down, But those Z06 guys.
Oh a few more thing:
turn your mirrors inwards so you dont hit them as you drive in the trailer ,
I use four 2x8s as addition ramps and lay them on top of each other under the trailers beaver tail. two of the 2x8 are 2 feet long and two are 4 feet long. I open the trailer ramp and set the ramp on the two foot 2x8s which are on top of the four foot 2x8s and then unfold the beaver tail. Make sure your wheels are lined up with the 2x8s to drive into the trailer.
ALso stablize the trailer. Hitched to your tow vehical and I got a small sissor jack from autozone and put it under the back end of the trailer before I open and bring down the ramp.
and block your trailers wheels.
Man I am tired now I think I need a beer.
Another question, given the low clearance on these cars and the strap angle I assume that there is minimal if any load on the suspension, correct? Also, do you take a measurement at the the hitch before loading,then re-measure after loading to determine hitch weight?
What brand trailer do you guys run?
I've read that tongue weight should be 10-15% of total trailer weight for proper handling, balance, etc, which for my 18" open trailer with the Z06 on it is about 500-750 lbs. This is very tough to measure though.
I'll admit, I swag this. I centered my car on the trailer wheels, marked the position of the front axle of the Z06 so I could get it in the same spot every time, then test drove it on my 5.9 L Durango. It drove fine, so I left it there. Now with my F350, I can barely even tell the trailer is back there, so I don't worry about so much. I know I have sufficient tongue weight because my fully loaded trailer (with tires on tire rack) causes the F350 to settle onto its load leaf springs.
I did look at them and decided I really didn't need one. I'm not convinced they are a good idea. When I looked at them it seemed they even the load by putting a huge load on the ball and the frame of the truck to put a counter torque to balance out the vertical load on the hitch. I didn't want the additional stresses on my ball, hitch or frame.
In my opinion (and I'm not an expert on this), I would rather spend my money on upgrading my rear suspension (i.e. air shocks or something) before a load distributing hitch. As I have an F350 that can take a 3295 lb payload in the bed (and tongue weight contributes to this load), I didn't need one.
Since you are asking towing questions, a couple other things to consider:
- anti-sway bars or shocks to prevent trailer swaying back and forth. With my long bed F350, my wheelbase is so long I don't need these now, but if my next assignment isn't overseas, I'll likely upgrade to a 24' enclosed trailer and then I'll get these.
- trailer brake controller. Amazingly, almost all trucks do not come with the electrical components necessary to activate electronic trailer brakes. I had a Teconsha brake controller installed in my F350 by a local RV place for just over $100. This box mounts under the dash within my reach. I can use it to set the current going to the trailer brakes, which allows me to vary it for unloaded and loaded conditions. It also has a button to activate the trailer brakes alone (normally it activates them when I press the brake pedal) to dampen trailer sway, but I've never had to do this.
As mentioned, make sure your straps are at least 10k lbs max limit or you'll be sorry. Also, you really should check the straps as mentioned every so often because they can become a little loose depending on your setup.
Best of luck!
Josh
I am a little surprised that non of you spoke of WHERE TO POSITION YOUR C5 IN THE TRAILER! The mirrors on a C5 is about the 50/50 balance point so that is where the C5 should sit above the trailers axles. Moving it forward puts more load on the trailer hitch, i.e. your tow vehicle, and moving it back makes the load tail heavy and it will not track properly. Depending on how much other stuff is on or in the trailer determines where the C5 goes relative to the trailers balance point!
Just my .02
JR
PS - DO NOT TOW WITH THE C5 IN PARK OR GEAR - USE THE EMERGENCY BRAKE OR CINCH IT DOWN AGAINST WEDGES FRONT AND REAR
