Chip?anyone.....?
I've seen a few places offer a an after market computer module that is suposed to replace your stock computer and remap the whole thing,raise the rev limiter,change the air/fuel ratio etc...u know how it works...
Now i was curious if anyone has an after market chip and what you think of it,i think it might not be a bad idea if you have the stage two(exhaust,intake)it might add some power?....
A lot depends on what your plans are for mods...and the availability of tuners in your area...
If you do heads and cam you will benefit from an LS1 Edit tune, if you go big on your cam you must have it...
If your sticking with bolt ons ... a hand held programmer such as the Preditor or the Vincci may do the trick
If your daring you can buy the LS1 Edit or HP Tuners program and learn to tune it yourself... but it could be an expensive lesson...
All of the above work by editing parts of the PCM files...
