Is 1/2 quart over filled too much?
Old Sep 7, 2004 | 11:29 AM
random access's Avatar
random access
Default Is 1/2 quart over filled too much?
I just put 7 quarts of mobil one in. Is it going to be a problem? The oil level is way above the full line on the dipstick. I let the oil drain for an hour to make sure I got all the old stuff out, so it was dry before I put new oil in.
Old Sep 7, 2004 | 11:32 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Not even close to being a problem. Don't sweat it. GM recommends adding a quart (over fill) when you do track days. I always put 7 in with each oil change on my car.
Old Sep 7, 2004 | 11:35 AM
random access
Dan you ARE the man! Thanks for the speedy reply, I was grumbling about having to go out and drain half a quart!
Old Sep 7, 2004 | 12:09 PM
BlueDragon's Avatar
BlueDragon
I also run 7 quarts, the sig Makes that obvious. and Yep GM recommends it if you do a lot of track and Auto-X.
Old Sep 7, 2004 | 12:53 PM
You should not have any problems going with 7 quarts. Many add this little extra if they race the car.
To Is 1/2 quart over filled too much?
