CLB needed on MN6?
Old Sep 8, 2004 | 12:51 PM
mdbennes's Avatar
mdbennes
Default CLB needed on MN6?
I have seen a lot of CLBs done on A4s, but not many on MN6s....I just bought a 00 MN6 and it doesn't have the CLB. Would it be a good idea to do it ASAP???
Old Sep 8, 2004 | 01:01 PM
glitch's Avatar
glitch
yes. MN6's need a CLB too...
Old Sep 8, 2004 | 01:02 PM
Yes, you certainly need a CLB on an MN6. They are relatively inexpensive and easy to install. Better than getting stranded somewhere.
Old Sep 8, 2004 | 01:29 PM
mdbennes's Avatar
mdbennes
I will try and get one this week....Hopefully its easy to install....
Old Sep 8, 2004 | 01:40 PM
ACELR8N's Avatar
ACELR8N
http://www.ls1howto.com/index.php?ar...bbd92a57ce0d1e
This is the install that I used. Bought mine from Corvettes of Houston. Quick delivery. Install was straighforward except for the one Murphys Law element in which a screw clip fell off the back of the knee panel, and I had to determine where it came from.
Old Sep 8, 2004 | 02:28 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
ASAP And yes those knee panel clips are a PITA .
Old Sep 8, 2004 | 02:32 PM
MLEN1UM's Avatar
MLEN1UM
Installed mine last week. Surprisingly it only took me 20 minutes! The instructions on LS1howto are great.
Old Sep 8, 2004 | 02:38 PM
roscoe118's Avatar
roscoe118
As a Wise Man once said....Can you plug in a toaster?
Yes, it it quite easy to install.
Old Sep 8, 2004 | 02:40 PM
mdbennes's Avatar
mdbennes
How many knee clips are there? I would be scared about breaking the knee panel when I take it apart....is there a trick to taking that off? Or will it just pop off?
Old Sep 8, 2004 | 02:51 PM
LiquidDI's Avatar
LiquidDI
It's easy to get the panel off. I didn't even take it all the way off. I just dipped the left side down and right back on it went. 10 minutes to put it in. Works great.
Old Sep 8, 2004 | 02:57 PM
mdbennes's Avatar
mdbennes
WHat if the buyer before me did it and I try to install it again....will this be a problem? I can't get a hold of the guy I bought this car from....Or will it be ok to do it again if he did it a long time ago?
Old Sep 8, 2004 | 02:59 PM
LiquidDI's Avatar
LiquidDI
you can tell if it's already been done. With the car off see if the column will lock. If it locks then it's not done.
Old Sep 8, 2004 | 03:04 PM
mdbennes's Avatar
mdbennes
Great...I will try that....
To CLB needed on MN6?
