Sun Visor removal problem
Old Sep 8, 2004 | 09:40 PM
frank dupuy's Avatar
frank dupuy
Default Sun Visor removal problem
I would like to remove the sun visor from my 04 vert. Tried the screwdriver method without any success. Some advice needed.
Old Sep 8, 2004 | 10:35 PM
2k1vert's Avatar
2k1vert
I too had trouble, but it did work... Jus took a forceful arm pushing up while using the screw driver.
Did you follow these instructions?
Visor Removal
Old Sep 8, 2004 | 11:03 PM
frank dupuy
I followed the directions as stated in Visor Removal without success. I was thinking the 2004 vert might be different.I stripped out the slot and was reluctant to go any further.
Old Sep 12, 2004 | 01:11 PM
MrLeadFoot's Avatar
MrLeadFoot
I just removed my passenger side visor, and found that the driver's and passenger's sides rotate in opposite directions. Maybe that's your problem. You basically have to rotate the visors toward the doors.
Old Sep 12, 2004 | 01:31 PM
frank dupuy
I did the rotation with the screwdriver inserted toward the door as stated. The only result was the screwdriver stripping out the slot in the plastic ring. I tried numerous times with the same result. Had to give up in frustration. This is why I think the 04 vette might need a different technique.
Old Sep 12, 2004 | 01:36 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hmmmm...I had to swing the one on my 99 out past the door to get it out
Old Sep 12, 2004 | 03:31 PM
G-lock's Avatar
G-lock
I too can't seem to get the visor to come out. It's almost like the inner bezel is stuck. All I seem to do is strip out the slot in the inner bezel. I used a fair amount of force to move the visor toward the door but I'm stumped. What's interesting it that in the tech tip pic the visor shaft is steel and mine are plastic, I wonder if this makes any difference. Any thoughts would be appreciated. Thanx, Jeff
Old Sep 12, 2004 | 08:29 PM
Mikef714's Avatar
Mikef714
I removed the driver side visor on my 2004 a few months ago to install a new one with Homelink. I followed the directions on several posts and got the visor off but broke the plastic retainer on the visor. I thought that I must have done something wrong, maybe applied too much force. The replacement visor had the part that I broke. Maybe a 2004 is different?
Old Sep 12, 2004 | 08:35 PM
G-lock's Avatar
G-lock
I got it off as well but alas, I broke the inner bezel as well. I hope that I can get the bezel seperately, but it looks like I'll have to order a whole new visor unless I can dig up the part I'm looking for. Crappy design but I probably works well on the line. Jeff
Old Sep 12, 2004 | 10:40 PM
CJS's Avatar
CJS
Geez, this is no good news! I wrote the removal tip 3 years ago, but it was only from experience on my 2001 model.
Lets stay on top of this and if a new technique for the newer cars is needed, lets put a date cut-off on the "old" tips and write a new one for the new style visors.
No good for people breaking their visors.
Old Sep 13, 2004 | 09:07 AM
G-lock's Avatar
G-lock
CJS-
I think we have the right procedure since I had both your tech tip and the instructions from the service manual. I think that there may be instances where the parts were not properly aligned when installed which allows the visor to work properly but then you can not remove it without destroying the inner bezel. I say this due to the way the top of the inner bezel is shaped it can only come out one way and if the two are assembled in the wrong phasing it will not disassemble. I think this is a crappy design but I'm sure it works well on the line as it is all snap together. The really tough part is that to get the inner bezel may require the purchase of a new visor since my parts list doesn't show it seperately. Jeff
New info!!!
After a long session with the dealers parts computer we did find the inner bezel part number! I ordered a couple and if they are the correct ones I'll post the info here. I also expect to see if I can figure out why the darn thing would come apart like it was supposed to.
Old Sep 13, 2004 | 04:16 PM
frank dupuy
Default Klutz
I am relieved to see others having this same problem. I was begining to think I was an incompetent mechanical klutz and lucky to just zip up his own zipper without damaging something.
Old Sep 13, 2004 | 07:19 PM
VetteSiNz's Avatar
VetteSiNz
Those screws are really hard to take it off. Need a little patience and it will come out.
Old Sep 13, 2004 | 08:04 PM
G-lock's Avatar
G-lock
VetteSiNz-
There are no screws??? Jeff
Old Sep 13, 2004 | 09:22 PM
jmesox's Avatar
jmesox
Mine came out with no trouble. Firm upward pressure and rotated it a little pass the door. I did buy a new inner bezel but did not use it. I'll save it for next time.
John
Old Sep 14, 2004 | 08:53 AM
G-lock's Avatar
G-lock
John
John-
Upward pressure on the visor or the screwdriver?? The problem that I and a few other have had is the dang thing won't rotate, I bent a small screwdriver and then a slightly larger one stripped out the slot in the bezel. Oh well, I'll get it figured out. Jeff
Old Sep 14, 2004 | 03:16 PM
G-lock's Avatar
G-lock
Well unfortunately my dealer failed me, the bezels we ordered were the outer ones, aggghhh. I was gonna use one, but the parts guy goofed and ordered both for the passenger side, but the good news is they are letting me return them even tho they were a special order. So the moral of the story appears to be that if you wreck the inner bezel either leave the visor in place or prepare to buy a new visor somewhere. What a lousy desgin in a 45,000 dollar car. Jeff
To Sun Visor removal problem
Old Sep 14, 2004 | 04:32 PM
Antonio BananaS's Avatar
Antonio BananaS
does it look better to take the visors out? i'm debating between looks vs. functional issues...
Old Sep 14, 2004 | 05:57 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Hey Bananas, never know whether you're serious or pulling our leg. But, for practical reasons, you'll want them if you have to drive into the sun and they help deflect the air with the top down.
Old Sep 14, 2004 | 06:48 PM
frank dupuy
If you figure this one out send me a personal on your technique. I have spent more time on trying to remove the driver side visor on my 04 C5 vert (without success) than it took me to install my Borla Stinger exhaust + 2 wax jobs. Every time I get in my car I look at that visor and feel totally disgusted and defeated by the plastic bezel from (hell).
