born-on-date please!
1G1YY22G2Y5100349
Thanks very much
RC 00034 LAP BELT WEBBING TWISTED 11/15/2000 Open
Open Recall:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004 Open
SERVICE INFORMATIONAL ITEMS
VIN 1G1YY22G2Y5100349
VEHICLE BUILD
Merchandising Model : 1YY07 -2000 CORVETTE COUPE
Gross Vehicle Weight Rating : 1675 kg (3693 lb) Order Number : 120G68
Build Date : 07/19/1999 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY CONVENIENCE PKG AG2 - 6 WAY POWER SEAT ADJ - PASS
AK5 - NEXT GENERATION DRIVER & RGHT FRONT PASSENGER AIR BAGS AQ9 - SEAT FRT BKT, PASS/DRIVER RECL
AX4 - EUROPEAN SEAT BELTS BAG - EXPORT PARTS PACKAGING
BGR - PLANT CODE-BOWLING GREEN, KY B34 - FRONT FLOOR MATS
B4H - EXPORT MOD NOISE CONTROL CF7 - REMOVABLE SUN ROOF
CJ2 - AUTO TEMP CNTRL SYST. CT1 - COUNTRY - BELGIUM
DL8 - MIRROR O/S REM, ELECT, HEATED D42 - RR COMPARTMENT SECURITY SHADE
EXP - EXPORT PROCESSING OPTION FE3 - SPORT SUSPENSION SYSTEM
GU6 - 3.42 REAR AXLE RATIO IL3 - INTERIOR TRIM DESIGN
JL9 - PWR DISC ANTILOCK BRK SYS FR&RR K29 - MODULE POWERTRAN CONTROL
K63 - 110 AMP GENERATOR LS1 - 5.7L 8 CYL SFI ENGINE
MAE - MARKETING AREA EUROPE PROCESSING OPTION MM6 - TRANSMISSION: 6 SPD MANUAL
MN6 - 6 SPD MAN TRANS NA7 - EUROPEAN EMISSION SYSTEM
NK4 - LEATHER SPORT STEERING WHEEL NP7 - EEC APPROVED STEERING COLUMN
QD4 - STYLED ALUMINUM WHEELS T62 - DELETE DAYTIME RUNNING LAMP
T82 - AUTO ON-OFF CONT HEADLAMPS T84 - RH RULE E MARK HEADLAMPS
T89 - EXPORT TAIL & STOP LAMP T90 - EXPORT SIGNALING & MARKER LAMP
T96 - FOG LAMP UL0 - RADIO: AM/FM STEREO, SEEK/SCAN AUTO REV MUSIC SEARCH CASSETTE AUTO TONE, CLOCK, ETR
UL2 - EUROPEAN RADIO FREQUENCY UV6 - HEAD UP DISPLAY
UV7 - REAR WINDOW ANTENNA UZ6 - 6 SPEAKER SYSTEM
U1S - MULTIPLE COMPACT DISC PLAYER U19 - KILO SPEEDOMETER & ODOMETER
U52 - ELECTRONIC INSTUMENTATION PANEL VC5 - EXPORT SHIPPING LABEL
VD1 - EUROPEAN OPTIONS PROVISION VG1 - UNDERHOOD PROTECTION
VG9 - EXTERIOR BODY WAX PROTECTION VH5 - VEHICLE IDENTIFICATION PLATE
VL4 - FR LICENSE PLATE MOUNTING EEC V76 - TOW HOOK
V78 - DELETE VEHICLE STATEMENT XGG - P245/45ZR17 BW FRT TIRES
YGH - P275/40ZR18 BW RR TIRES Z51 - PERFORMANCE PACKAGE HANDLING
1SB - PREFERRED EQUIPMENT GROUP 1SB 70I - TORCH RED INTERIOR TRIM
70U - TORCH RED 703 - TORCH RED LEATHER
1gyy32gxw5112087
VIN 1G1YY32GXW5112087
VEHICLE BUILD
Merchandising Model : 1YY67 -1998 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1677 kg (3698 lb) Order Number : 927AXK
Build Date : 11/19/1997 Build Plant : 1W5Y - BOWLING GREEN
OPTION CODES
AG2 - SIX-WAY PASSENGER POWER SEAT AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT LEATHER BUCKET BGR - BOWLING GREEN PLANT
B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS B84 - BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - FEDERAL EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI, V8 MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL QD4 - STYLED ALUMINUM WHEEL
R9Z - POMS EXPEDITE - SOLD ORDERS T96 - FOG LAMPS
UL0 - AM/FM STEREO CASSETTE RADIO UZ6 - QUAD SPEAKER SYSTEM
U1S - COMPACT DISC PLAYER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AZ - SOLD ORDERS PROC OPTION
1SB - OPTION PACKAGE - BASE 13U - SILVER SEBRING METALLIC
41T - T0P-BLACK 92I - MED GRAY INTERIOR TRIM
923 - PEWTER LEATHER
VEHICLE BUILD
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1678 kg (3700 lb) Order Number : BQHRN5
Build Date : 08/03/1999 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - FEDERAL EMISSIONS G90 - REAR AXLE-3.15 RATIO
G92 - PERFORMANCE AXLE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QD4 - STYLED ALUMINUM WHEEL T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
1SA - OPTION PACKAGE - BASE 19I - INT EBONY INTERIOR TRIM
193 - BLACK LEATHER TRIMMED SEATING SURFACE 41T - T0P-BLACK
70U - TORCH RED
Many thanks.
VEHICLE BUILD
OPTION CODES
thanks
Can you please provide me with the born-on-date also. I'd really appreciate it. Thanks
VIN #1G1YY32G145129213
Dave
VEHICLE BUILD
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1665 kg (3671 lb) Order Number : HBWBX4
Build Date : 05/04/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
LS1 - 5.7L LITER SFI V8 - 350HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
YGH - REAR TIRE-P275/40ZR18 BW SBR Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS)
1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN 1SZ - PREFERRED EQUIPMENT SAVINGS
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
41T - T0P-BLACK 88U - MEDIUM SPIRAL GRAY METALLIC
1G1YY12S345108937
mark
1G1YY12S345108937
mark
VIN 1G1YY12S345108937
VEHICLE BUILD
Merchandising Model : 1YY37 -2004 CORVETTE Z06
Gross Vehicle Weight Rating : 1614 kg (3559 lb) Order Number : GPVHQ6
Build Date : 09/26/2003 Build Plant : 145Y
1G1YY32P4S5115917
First, many thanks - very useful information
Useful because there are some things about the car that do not match this data - The EU Cert of Conformity that came with it said it was manufactured in September 2000, just a little bit out, don't you think? The interior is black and it has mag wheels.
Love the car still (obviously) but I think American Dreams in the UK might be getting a visit . . . . about a cash adjustment I ought to add.
VEHICLE BUILD
Thanks again Sponge Vette. I bought the car new in April 2004. Wow! That means the car went unsold for 7 months. I know the dealer I bought it from got it from another dealer. The original dealer must have sat on it for a long time and finally gave up. I wonder if this is typical.
mark
1G1YY12S345108937
mark
VEHICLE BUILD
OPTION CODES
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
FE4 - RIDE & HANDLING SUSPENSION SYSTEM GU6 - REAR AXLE 3.42 RATIO
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV NK4 - LEATHER WRAPPED STEERING WHEEL
P12 - CAST ALUMINUM WHEEL SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U73 - FIXED MAST ANTENNA
VDC - VEHICLE INFORMATION CD VG6 - NOTICE TO BUYER LABEL - 5 MPH BUMPER IMPACT
VG8 - NOTICE TO BUYER LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFW - FRONT TIRE-P265/40R17 YFU - REAR TIRE-P295/35R18
YF5 - 50-STATE EMISSIONS 1SA - BASE EQUIPMENT GROUP
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
194 - Z06 INTERIOR - BLACK 79U - PREMIUM COLOR MILLENIUM YELLOW
1G1YY32P4S5115917
VIN 1G1YY32P4S5115917
VEHICLE BUILD
Gross Vehicle Weight Rating : 1753 kg (3865 lb) Order Number : 1047TF
Build Date : 05/11/1995 Build Plant : 1S5Y - BOWLING GREEN
OPTION CODES
AG1 AG2
AK5 AQ9
AU0 BGR
C05 C68
DL5 DL8
FE1 FE9
G44 G92
IL3 J55
KG9 LT1
MX0 M30
NA5 NK4
QB6 R7A
R8T UJ6
UX0 U1F
U52 U75
VM3 V73
WY5 XFR
YFS 1AY
1SD 34T
64I 643
75U
Here is a link that tells you what the codes mean
description of options
VIN# 1G1YY32G445116357
Many thanks
