born-on-date please!
Old Sep 9, 2004 | 06:31 PM
Antonio BananaS's Avatar
Antonio BananaS
Default born-on-date please!
can i please get the birth info and more about my baby? #1G1YY32G845126034
thank you for your help!
Old Sep 9, 2004 | 06:36 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
VIN 1G1YY32G845126034
VEHICLE BUILD
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1669 kg (3680 lb) Order Number : GVST69
Build Date : 03/25/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE F55 - MAGNETIC SELECTIVE RIDE CNTRL
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NC1 - CALIFORNIA EMISSIONS LEV
NC7 - FEDERAL EMISSIONS OVERRIDE NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VDC - VEHICLE INFORMATION CD
VG6 - NOTICE TO BUYER LABEL - 5 MPH BUMPER IMPACT VG8 - NOTICE TO BUYER LABEL
V49 - LICENSE PLATE FRAME: FRONT V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YF5 - 50-STATE EMISSIONS
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING 41T - T0P-BLACK
67U - MACHINE SILVER
Old Sep 9, 2004 | 07:03 PM
BobH's Avatar
BobH
Isnt the born on date on a sticker on the driver's door?
Old Sep 9, 2004 | 07:09 PM
Sponge Vette
NO!
Old Sep 9, 2004 | 07:15 PM
DRR's Avatar
DRR
Sponge Vette, Could you also give me a born on date, history, ect. Thanks, Doug VIN -1G1YY32G4W5120413
Old Sep 9, 2004 | 07:35 PM
Sponge Vette
Check your IM.
Old Sep 9, 2004 | 07:55 PM
DRR's Avatar
DRR
Thanks again, Doug
Old Sep 9, 2004 | 08:14 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
Please one more! Looking for a born on date for 1G1YY22G045113904
Thanks!
Old Sep 9, 2004 | 08:26 PM
Sponge Vette
Thanks!
VIN 1G1YY22G045113904
VEHICLE BUILD
Merchandising Model : 1YY07 -2004 CORVETTE COUPE
Gross Vehicle Weight Rating : 1672 kg (3687 lb) Order Number : GSDB3W
Build Date : 11/11/2003 Build Plant : 145Y
OPTION CODES
B84 - BODY SIDE MOLDINGS CF7 - REMOVABLE ROOF PANEL
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS) 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
193 - BLACK LEATHER TRIM SEATING 67U - MACHINE SILVER
Old Sep 9, 2004 | 08:27 PM
BobH's Avatar
BobH
Originally Posted by Sponge Vette
NO!
Then whats that sticker on the drivers door that says "this vehicle conforms with all the .............." its dated July,03. At the bottom of the sticker is the Vin#. I thought this was the born on date? I guess that's not it huh?
Old Sep 9, 2004 | 08:33 PM
Sponge Vette
Then whats that sticker on the drivers door with a July 3, 03 date on it?
Post the last 8 digits of your vin# and will see when yours was built. I don't think it was 7/3/03
Old Sep 9, 2004 | 08:39 PM
BobH's Avatar
BobH
Okie Dokie, here are the last 8 numbers, 45102162. Thanks !
Old Sep 9, 2004 | 09:41 PM
Sponge Vette
VEHICLE BUILD
Gross Vehicle Weight Rating : 1668 kg (3678 lb) Order Number : GHVZ7B
Build Date : 07/28/2003 Build Plant : 145Y
OPTION CODES
CF7 - REMOVABLE ROOF PANEL CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS GU2 - REAR AXLE 2.73 RATIO
1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN 1SZ - PREFERRED EQUIPMENT SAVINGS
67I - LIGHT OAK INTERIOR TRIM 673 - LT OAK SEATING TRIM
70U - TORCH RED
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2004 CORVETTE COUPE Warranty Start Date : 04/22/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MIKE PALLONE CHEVROLET, LLC
7722 BACKLICK RD
SPRINGFIELD , VA 22150-2209
(703) 451-4511
Well what do you think now. Hate to say I told you so.
Old Sep 9, 2004 | 09:48 PM
steven57's Avatar
steven57
Sponge, could you please research the following:
1G1YY32G5W5117990
Thanks much!
Old Sep 9, 2004 | 10:09 PM
GrayC5's Avatar
GrayC5
No, this is not you're "born-on" date. But, the wording on this label is somewhat confusing. The date on this label on my car is 03/03 which I assume is month and year. However, my car's born on date is 03/24/03. Sponge Vette can get you the correct "born-on" date for your car.
Edit: I see Sponge Vette just now provided you with your "born-on" date:
Old Sep 9, 2004 | 10:33 PM
Sponge Vette
1G1YY32G5W5117990
Thanks much!
VIN 1G1YY32G5W5117990
VEHICLE BUILD
Merchandising Model : 1YY67 -1998 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1685 kg (3715 lb) Order Number : 994BZA
Build Date : 01/30/1998 Build Plant : 1W5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY PASSENGER POWER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AR9 - LEATHER BUCKET SEATS
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
C05 - CONVERTIBLE FOLDING ROOF DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - FEDERAL EMISSIONS G90 - REAR AXLE-3.15 RATIO
G92 - PERFORMANCE AXLE RATIO IP3 - TRIM INTERIOR DESIGN - AR9
JAG - BRAKE PROVISIONS ABS LOCATION JL9 - 4-WHEEL ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI, V8
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF2 - FEDERAL EMISSION SYSTEM, TIER 1 NK4 - LEATHER WRAPPED STEERING WHEEL
QD4 - STYLED ALUMINUM WHEEL R6E - - AQ9/+AR9 IDENTIFIER
T96 - FOG LAMPS UL0 - AM/FM STEREO CASSETTE RADIO
UZ6 - QUAD SPEAKER SYSTEM U1S - COMPACT DISC PLAYER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1AY - STOCK ORDERS PROC OPTION
1SB - OPTION PACKAGE - BASE 11U - LT PEWTER METALLIC
67I - LIGHT OAK INTERIOR TRIM 67T - T0P-LIGHT OAK
673 - LIGHT OAK LEATHER
Old Sep 9, 2004 | 10:56 PM
BobH's Avatar
BobH
VEHICLE BUILD
OPTION CODES
70U - TORCH RED
VEHICLE INFORMATION
7722 BACKLICK RD
(703) 451-4511
I was mistaken about the july 3 date it was the 28th. Interesting that the car was built in july of 03 but I bought it new in april of 04. I wonder what it was doing all that time?
To born-on-date please!
Old Sep 9, 2004 | 11:41 PM
Ron H's Avatar
Ron H
Please
1G1YY32G7Y5101762
Old Sep 10, 2004 | 03:43 AM
Cochemarman's Avatar
Cochemarman
While you are being so very helpful Sponge Vette, could you tell me when my Katie Corvette was born?
1G1YY22G2Y5100349
Thanks very much
Old Sep 10, 2004 | 05:59 AM
Sponge Vette
Originally Posted by Ron H
Please
1G1YY32G7Y5101762
VIN 1G1YY32G7Y5101762
VEHICLE BUILD
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1678 kg (3700 lb) Order Number : BQHRN5
Build Date : 08/03/1999 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
G92 - PERFORMANCE AXLE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QD4 - STYLED ALUMINUM WHEEL T96 - FOG LAMPS
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
1SA - OPTION PACKAGE - BASE 19I - INT EBONY INTERIOR TRIM
193 - BLACK LEATHER TRIMMED SEATING SURFACE 41T - T0P-BLACK
70U - TORCH RED
