Braided Hose Covers
I have a braided hose cover kit that I picked up at the FunFest last year and since it is a week away from this years FunFest I thought it might be a good idea to maybe even install them.
Question is, if I disconnect the upper radiator hoses in order to install the covers, will I have to drain the coolant ? Or can I take off those hoses without any leakage. My sense is that it will leak out, but I was hoping for the quick mod and I didn't want to find out the hard way.
Forum Members know best
Dave
If done right, you can make new hoses for ac line and have the covering crimped on, then you dont need extra clamps. Not trying to be a spoil sport. I have put a lot of the sutff on, it can be a real bear to get tight ove the hose to make it look good. And yes, you will get anitfreeze running out, make sure you get the air pockets out if the system...
I put some of this same covering on my hoses, I took my time and got them on and it looked pretty good for a few weeks but then it started to darken up and with all the work I do on my car the braids would get dirty then when I'd clean them up the braids would get bent out of shape so I pulled them all off
