Outside Heat vs. C5 voltage system
Old Sep 10, 2004 | 10:17 PM
webdzynes's Avatar
webdzynes
Default Outside Heat vs. C5 voltage system
I just moved to Florida where the daily average temp has been 92 & my car sits in the sun besides. My voltage was OK (13.5) but essentially since Ive been here (2 months), my voltage drops to only around 12.1 during the day when the heat is the highest and the A/C is on. I have a yellow top battery but am wondering if this is indicating I need a new alternator...Suggestions?
Old Sep 11, 2004 | 11:34 AM
Blown2K's Avatar
Blown2K
That doesn't sound right. It's been in the high 90's here where I live in southern CA and my voltage is a little over 13 with the AC on.
Old Sep 11, 2004 | 11:41 AM
tT-REXXX's Avatar
tT-REXXX
Default Yellow top
Most c5 owners use red top Why yellow. Do have any high draw after market items installed.The way these two batt.draw current may be different.I don't know,but i'm sure sombody here does
Old Sep 11, 2004 | 10:54 PM
webdzynes's Avatar
webdzynes
I have a fairly high powered stereo so the yellow top was the recomended one on the forum. However, I have not played it much and certainly not loud since I've been down here...
Old Sep 12, 2004 | 12:01 AM
JC in XTC5's Avatar
JC in XTC5
Remember, the voltage while the car is running is the output of the alternator, not the battery voltage. When the car is not running the DIC will show a relative battery voltage of about 11.5V, which is lower than the actual voltage at the battery terminals.
What you're seeing is normal. I used to live in SoFlo. When it's hot and the A/C is on there is more load on the alternator and you may see the voltage dip a bit, but it will always remain the the normal range on the gauge.
To Outside Heat vs. C5 voltage system
