Another lowering question---
Old Sep 11, 2004 | 06:28 PM
dmoran1845's Avatar
dmoran1845
Default Another lowering question---
I have read and used the search engine on the forum to research all the lowering questions and answers that I could find. I put my on the stands, identified the bolt for the front, but could not get to it. I have the ride control function on my 98 Nass Coupe. One past thread stated that I had to undue the sway bars, lower shock bolts, and the ball joint bolt. Other threads say none of this. Which is the best way to do this and is there any special tools that I will need. Thanks.
Old Sep 11, 2004 | 07:12 PM
Davesredvette's Avatar
Davesredvette
Not sure about the ride control function but for mine I only needed to unbolt all of that stuff to pull the bolts out to cut the bushings down.
To just lower on stock bolts all I had to do is remove the front tire and unload the spring. Removing the front tire gave me access to the bolt with a socket or wrench. I needed to put the front on jack stands or use 2 floor jacks.
But the bolt won't turn unless you unload the spring by jacking up the area you are working on. I still had to put a 12" long piece of pipe on the wrench to turn the bolt....
Old Sep 11, 2004 | 07:16 PM
Pumba's Avatar
Pumba
Dave,
You need to be able to drop the lower control arm out of the way so you can remove the adjuster bolt.
Good luck lowering your C5.
Old Sep 11, 2004 | 07:24 PM
Davesredvette
Originally Posted by Pumba
Dave,
That is correct, but to just turn the bolt, the lower control arm can stay put.
Old Sep 11, 2004 | 11:12 PM
dmoran1845's Avatar
dmoran1845
Thanks for the info.
Old Sep 12, 2004 | 10:23 AM
Layne Staley's Avatar
Layne Staley
Don't lower the car, you'll kill it.
Old Sep 12, 2004 | 10:28 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
HUH!!?? This is the first time I have EVER heard that! Back-up references?
Old Sep 12, 2004 | 11:14 AM
Matt69-ZO6's Avatar
Matt69-ZO6
WTF?
Mine still seems to be alive and well - Of course I can't go off roading anymore the my 4x4 buddies.
Old Sep 12, 2004 | 12:04 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Just checked. Mine is alive and kicking.
Old Sep 12, 2004 | 12:13 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
LMFAO
Old Sep 12, 2004 | 01:13 PM
unchained's Avatar
unchained
Cruise-In VI Veteran
Cruise-In VII Veteran
I think I'd ignore Mr. Member since Sept. 2004 and go with the advice of those who've been around awhile and obviously know what they're talking about.
Old Sep 12, 2004 | 01:36 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Phew!!! Thank GAWD!!!! I was about to jack my car up and perform artificial resusitation by blowing on my air filter.
Old Sep 12, 2004 | 08:18 PM
DaBoz's Avatar
DaBoz
Stanley, you've spent too much time at stangnet Corvettes are just a little different than rustangs
Old Sep 12, 2004 | 08:21 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
To Another lowering question---
