??C5 with A4 Trans??
Old Sep 13, 2004 | 03:48 PM
pylant's Avatar
pylant
Default ??C5 with A4 Trans??
Hey guys,
Question.
Do you normally drive your auto transmission in third gear or overdrive (circle D)?
I have owned many a chevy truck and car and the owners manual has always said to run them in third gear position on hills, towing, stop & go traffic, etc. And to use overdrive on the freeway.
So is it better on the C5 transmission to run it in third gear position or the circle D position under normal twisty, hilly, stop and go traffic?
bp
Old Sep 13, 2004 | 03:53 PM
spiral04vette's Avatar
spiral04vette
From: Los Angeles I'm here for a good time, not a long time!
I have a 04 coupe A4 and I drive it in D not 3. I initially drove it in 3 but looked in the owners manual and it said D for normal driving. Well my version of normal driving is stop and go traffic since I live in S. Ca. so I don't know if its harming it in anyway, but I down shift to 3 when coming to a stop occasionally.
I don't think this helped but it gave another view.
Old Sep 13, 2004 | 03:58 PM
BlueDragon's Avatar
BlueDragon
I do a little of everything. In the City I normally rumble around in third. Sometimes I shift it like an manual. In traffic is saves on the brakes. Then on open highway I just put her in-a "D".
Some days I get lazy and just put it in Drive.
You heard about the Italian guy driving an American Muscle care right!
First he put-a-her in L for leap. Then he put her in D for-a-drag, and then he threw her into R for-a-race and the car she go-a caput@!
Old Sep 13, 2004 | 04:30 PM
Beast's Avatar
Beast
Leave the car in drive. The only time i ever downshift an automatic is to stop fast in harsh weather conditions, or start in 1 when racing. Although my vette doesnt see any weather at all so i just leave it in d. I believe you shouldnt mess with an auto to much, but thats just my opinion.
Old Sep 13, 2004 | 06:03 PM
IM QUIKR's Avatar
IM QUIKR
I keep mine in D unless I need controlled passing power. The D works well in-town because the C5 has enough torque that you'll only be at 1200rpm at 35 mph. I just let the car shift when driving normally. For AutoX, I start in 1, at 20mph I toss it into 2 and stay there as it seems to be good all the way to 80 mph.
Old Sep 13, 2004 | 06:12 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
I use 3 in town and occasionally 2 (sounds so good!) and D for the Hwy
Old Sep 13, 2004 | 06:23 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
...drive unless I am on the drag strip or on the autocross course...
Old Sep 13, 2004 | 06:49 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Drive for most city and highway driving. However, running curvy mountain roads, I go between 2nd and 3rd quite a bit.
Old Sep 13, 2004 | 07:18 PM
Purerock105's Avatar
Purerock105
I'm not sure if Better is a word I choose.
When I was stock I never took it out of D. Now modded with
gears/tc/TransGo I leave it in 3rd almost exclusively while
cruising around town, but when on the interstate and right
at 55 or 60 I shift it up to D.
Old Sep 13, 2004 | 07:46 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I use 3 when doing a canyon run or something ... It's keeps my tranny cooler by 20 degrees or so. Anytime you don't want your tranny "seeking" 4th, when you are doing a lot of high rpm, low rpm driving.
I also use it in slow traffic, as long as I don't over 55 mph.
Jusy my .02
Old Sep 13, 2004 | 08:29 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
usually in drive
Old Sep 13, 2004 | 08:45 PM
BobH's Avatar
BobH
Mostly Drive but not all the time. I drive on the Washington beltway a lot and there and above 55 its D. But sometimes I drive in 3 leaving the line for short peroids... just for fun!
Old Sep 13, 2004 | 10:24 PM
Davesredvette's Avatar
Davesredvette
It's gotta be 3 around town, I wanna hear the Borla's sing...
D is for the D-freeway - 60mph and above...
Old Sep 13, 2004 | 11:19 PM
C5 4 ME's Avatar
C5 4 ME
sounds familiar
Old Sep 13, 2004 | 11:34 PM
jrose7004's Avatar
jrose7004
I'am in D!
Old Sep 14, 2004 | 08:23 AM
sempi's Avatar
sempi
Default For what it's worth
When doing some shopping around for beefing up the transmission, I was told by two different performance shops, that the weakest part of the 4L60-E is the shift between third and fourth.
I am trying to track it down, but I also remember an engineer at GM also saying this a couple of years ago. He suggested that you run in third in stop and go traffic and basically anything under 50 MPH. I remember him saying this is how he ran his C5 and his TransAm. If I find this, I will post it.
Just my $0.02
Sempi
Old Sep 14, 2004 | 08:26 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Same here.
To ??C5 with A4 Trans??
Old Sep 14, 2004 | 10:29 AM
spiral04vette
Originally Posted by C5 4 ME
sounds familiar
Davesredvette and c5 4 me I tested out the 3 around town last night, and your right, I will be rolling in 3 from now on, LOVE THOSE GHLS BULLETS baby!!
D is for D'freeway!!
Old Sep 14, 2004 | 11:00 AM
mrgil's Avatar
mrgil
Burnout
Keep in mind that High RPM Low Load is bad for oil consumption.
jmho
mrgil
Old Sep 14, 2004 | 03:04 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Keep mine in 3rd around town...gives me better pick up when I need to scoot in a hurry ...use 2nd occasionally going down some of the steep hills around here. Definitely D once on the freeway...
