I am sure this is a thread that has been warn out. But i am new and have a couple of questions. I talked to my local Vette shop and they said I could drop the car up to 3/4 inch on the stock bolts. I love the look of a lowered Vette but i was wondering if there were any problems i could run into with the suspension once the car was lowered.
Thanks for the help
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Lowering on the stock bolts is a piece of cake - the only thing I would suggest is that you plan on a four wheel alignment after you're finished. Also, the suspension needs to settle - so plan on adjusting the ride height slightly after you've driven the car a little after the initial lowering. Good luck!
Cons - watch for speed bumps, driveway entrances, dips at high speed, debris on roadway, getting the car on a lift, interior being lit up like Times Square on the 4th of July at night with a pickup on your tail...and finally, if your car must be State inspected before you sell, it will not pass if it is not factory height (at least that's the case in MD).
Mine is right at 1" on stock bolts. I didn't cut the bushings to preserve the ride, but added the bump steer kit to help with alignment (which you should get after lowering).
its a great mod. But don't get the alignment immediately after you lower
it. Drive it some (100 to 200 miles) and give the springs time to settle (5 -
7 days).
Lowering:
Choice is yours.
Ya but you can always put it back to stock height with little trouble.
I installed lowering bolts from West Coast Corvette in the back of my 99 coupe along with a set of Bilstein sport shocks all round. I lowered the front on the stock bolts. Wow, what a difference over the FE1. My only concern was bottoming out the shocks which has not been a problem.
I would not recommend using the lowering bolts with stock shocks though, the back dropped more than 3/4 of an inch which could blow them out.
I got all excited reading these threads and decided to lower mine too. Another thread said you had to push real hard to get the front bolts to turn. I pushed hard and ended up stripping the 10mm bolt. I guess it is only a problem if I intend to turn it again, but I'd like to know if anyone has ideas on how to fix the bolt without taking the car to a shop (never trust those guys.)
Thanks for the help
I lower my car appoximately 1/2". I went to the dealership, they said no alignment is needed until you reach 1" or more.
Ok, so how do you lower it on the stock bolts ? Is there a specific process that needs to be followed? How much thread needs to be left on the bolt, etc.........
You'll have to probably replace the bolt. But you have to jack up the spring to relieve the pressure to do the fronts.
Thanks for any info you guys / gals can provide.
I lowered my z06 on Sunday using these instructions as reference:
I did one end of the car at a time. Drive that end of the car up onto some 2x10 blocks of wood, then jacked up that end on the suspension crossmember jacking points, removed the wheels, used a second jack on the front leafspring with a block of wood wrapped in cloth between the jack and the leafspring to relieve pressure on the bolt, etc. It seems to have worked - I think the Z06 is so high from the factory that now it still doesn't even look lowered.
