Might be a dumb question...
Sep 16, 2004 | 10:24 AM
Can you switch out your standard AC controls for dual climate control?
Sep 16, 2004 | 10:26 AM
St. Jude Donor '06 thru '15, '19
Not sure but I would say its not worth any hassle if you can .
Sep 16, 2004 | 10:32 AM
Thats what I was thinking too..sounds like a lot of computer crap needs to be added...
Sep 16, 2004 | 10:58 AM
2017 C7 of the Year Finalist
St. Jude Contributor
Quote:
Don't bother.
I have the Dual Zone and if the switch was easy, I'd offer you my Dual Zone for your standard even up.
The Dual Zone is overkill..................
Sep 16, 2004 | 11:02 AM
Quote:
Originally Posted by Glennm27
Don't bother.
I'm solo in my car 90% of the time and the few times I have with passengers - they don't need to be messing with my dash anyway.
Sep 16, 2004 | 11:24 AM
And the area in the C5 is so small any ways I think the dual climate is overkill also!
Sep 16, 2004 | 01:14 PM
You can, but it is a lot of work and lot of expense. Not sure it is worth it.
Sep 16, 2004 | 01:23 PM
No you cannot for the following reasons:
Dual zone uses 3 sensors (Internal Air Temp, External Air Temp, and Sunload) that are not in the base car.
The Dual Zone plumbing in the dash is different to provide separate driver and passenger airflow and uses multiple flow doors to control the airflow. The whole dash would need be torn apart.
Most important, the Dual Zone uses electronic actuator motors to control the flow doors, while the base system uses vacuum actuators. Swapping that out would require major work.
Sep 16, 2004 | 02:07 PM
Don't bother.
I had the manual AC in my 99, I now have an 04 with the Dual Zone system, I want my manual AC back.
Sep 16, 2004 | 02:13 PM
I love the dual zone! Set it and you don't have to turn a thing. How could you want to get rid of that???
Sep 16, 2004 | 02:16 PM
Captain, What are you up to? The reason I ask is that I see in your signature that your blue vette is sold.
