"Fluttering" Turn Signal
Old Sep 18, 2004 | 07:22 PM
RaceMic's Avatar
RaceMic
Default "Fluttering" Turn Signal
My right turn signal is 'fluttering' when I first turn it on. Because it soon settles down to a normal sequence, I am unable to figure out what is happening or why. Any similar experiences?
Old Sep 18, 2004 | 07:24 PM
DRR's Avatar
DRR
Are your right signal lamps front and rear working? Doug
Old Sep 18, 2004 | 07:33 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Sounds like one of the bulbs is either out on or it's way out.....
Old Sep 18, 2004 | 07:50 PM
LoneStarFRC's Avatar
LoneStarFRC
Intermittent contact possibly and maybe due to corrosion in the socket or a bulb with a filament that's broken and occasionally opening up. Probably a front one. HTH
Robert
Old Sep 18, 2004 | 08:15 PM
CarsRFun's Avatar
CarsRFun
my left blinkers blinks fast right does not front blinks back does not *left side* 4 ways all blink normal speed????
anyone have any ides on this one?
Old Sep 18, 2004 | 08:22 PM
LoneStarFRC
Sounds to me like you've got one (or more) lights out on the driver's side. Rapid blinks will tell you which side needs attention when in the turn signal mode. The hazard flashers are set up to flash a constant rate, regardless of which side may have a burned out bulb. HTH
Robert
Old Sep 18, 2004 | 09:26 PM
CarsRFun's Avatar
CarsRFun
so i should just replace all the bulbs on the drivers side?
as in Headlights because its just the blinker that is effected?
Old Sep 18, 2004 | 10:29 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
You know you have two speed directionals? The first contact is temporary,fast. The second one is normal. If your bulbs are working, don't waste your money replacing the bulbs. It's normal.
Old Sep 18, 2004 | 11:33 PM
BobH's Avatar
BobH
When I hit my Right Turn signal it flutters at first. I think this is because its a "push" (more akward) effort on the wand instead of a "pull". This effectively causes the wand to be at the Temporary (fast) setting unless I push it all the way up. Maybe you are doing the same thing?.. Just my 0.2
Old Sep 19, 2004 | 02:19 AM
CarsRFun's Avatar
CarsRFun
but the front will blink really fast and the back will not blink at all, if the front is normal then the back is too.
Old Sep 19, 2004 | 02:42 AM
Chief777's Avatar
Chief777
St. Jude Donor '15
Rapid blinking is usually a signl that one of your lights are out. Sounds like you need to repace your rear turn signal bulbs. I would try replacing bulbs before you bring it into a shop, you should be able to replace all of them before you pay for an hour of labor in a shop.
Good Luck.
To "Fluttering" Turn Signal
