Waterspots on windows problem
Old Sep 17, 2004 | 07:59 AM
VetteHunting's Avatar
VetteHunting
Default Waterspots on windows problem
I have a problem that I really have no idea how to handle even though its a rather small one. I have waterspots on my front and rear windows that will not wash or rub off. I have tried Napa glass cleaner with ammonia to no real avail. The spots seem to be "cooked" on. Any ideas of what to do? Thanks, Darroch Malone
Old Sep 17, 2004 | 08:02 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
It's probably calcium from the water. You might try soaking a paper towel in water/cleaner and just putting it on the spots for a while before cleaning.
I use Stoner's Invisible Glass to do my windows and that stuff is fantastic. No streaks, or anything.
Good luck.
Old Sep 17, 2004 | 08:59 AM
ic98's Avatar
ic98
Use some Bon Ami on your windows and it will remove the spots.
Old Sep 17, 2004 | 09:18 AM
mdbennes's Avatar
mdbennes
Or try vinegar and water as well....
LANZ06's Avatar
LANZ06
Try my method. KEEP IT OUT OF THE RAIN !!! Really, a little white vinegar will get rid of them.
Old Sep 17, 2004 | 09:19 AM
SilverRoadster00's Avatar
SilverRoadster00
I use Stoner's as well, may take a few applications. I've also heard the trusty clay bar can clean windows well.
Old Sep 17, 2004 | 09:20 AM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Clay bar if they are bad.
Then Stoners!
Old Sep 17, 2004 | 09:25 AM
ROADAPPLE's Avatar
ROADAPPLE
Works every time
Old Sep 17, 2004 | 09:32 AM
unchained's Avatar
unchained
Cruise-In VI Veteran
Cruise-In VII Veteran
I use Stoner's Invisible Glass for everyday use. It works great!
I've heard that the stuff you can get from www.diamondite.com works wonders on old, hard-to-remove water spots.
Old Sep 17, 2004 | 12:28 PM
Tim2K4Vert's Avatar
Tim2K4Vert
A 50/50 mixture of white vinegar and water will take the water spots off.
Old Sep 17, 2004 | 12:31 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Also, you can try making a paste out of baking soda/water. It acts like a very mild abrasive.
Old Sep 17, 2004 | 12:51 PM
Chris Lemoine's Avatar
Chris Lemoine
From: You invited Eric? I thought Eric gave you the creeps!
Zaino glass polish. Its the best thing I have found to remove water spots on glass. After you get them off apply some polish to your glass to give a little protection.
Old Sep 17, 2004 | 12:58 PM
srchief100's Avatar
srchief100
Vinegar and water will remove lime/calcium buildup for sure. Then follow up with a good glass cleaner - Stoners, Zaino, etc. A good protectant applied afterwards, and a final buffing with cheese cloth will make it spotless, and much easier to clean the next time.
Old Sep 17, 2004 | 01:20 PM
Vinegar/water works pretty well. It has taken some water spots off mine when nothing else would.
Old Sep 17, 2004 | 02:06 PM
Jackal's Avatar
Jackal
I have tried everything above before except for the zanio product. Nothing worked. I then tried 3m rubbing compound. Worked like a champ!!! My windows have never looked better.
Old Sep 17, 2004 | 02:39 PM
Yoggi's Avatar
Yoggi
Old Sep 17, 2004 | 03:30 PM
Hoosier Red's Avatar
Hoosier Red
To Waterspots on windows problem
Old Sep 17, 2004 | 03:43 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
i get them on my cars that are outside and i cant get them off. i dont know what it is in the rain around here but it jacks some windows up!
i have tried bar keeps, stoners, vinager, even 000 steel wool and zaino glass polish.
i have heard that chrome polish works pretty good, but havent tried it yet.
if your rain is anything like it is here in maryland, then its gonna be hard to get them off.
Old Sep 17, 2004 | 03:53 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
I don't think anyone has mentioned this yet but try some vinegar and water.
Old Sep 17, 2004 | 04:34 PM
VetteHunting
Well seeing as how I have no idea where to buy half of these products, I think I'll try one that nobody has mentioned yet. Vinegar and water supposedly works well with a 50/50 mixture! Thanks guys, Darroch Malone
