The one thing you need to watch out for in 2001 is oil consumption. In 2001 GM went with a thinner ring and under heavy footed driving conditions the 01s eat a lot of oil. GM determined the oil eating was not really harmful to the motor more of a nuisance then a harmful problem. They did however re ring the cars if consumers complained. You can ask the dealer to run the cars warranty repair history this would be helpful and you could also see if a former owner had the re-ring job done. Hope this helps.
HP numbers are the same (350). Appearance is the same except for some color options (interior and exterior). Like was mentioned above, watch the '01's for oil consumption.
