HALLTECH vs BLACKWING
Old Sep 19, 2004 | 11:28 PM
mdbennes's Avatar
mdbennes
Default HALLTECH vs BLACKWING
Which one out performs the other? I have read problems with the hood on the HALLTECH, is this a problem with the Blackwing as well?
Mike
Old Sep 19, 2004 | 11:33 PM
StevieB's Avatar
StevieB
I'm one of the few that had a problem with the hood closing over the Stinger air bridge. I ended up using my stock air bridge with the Stinger filter element. It is my understanding that the Blackwing uses the stock aribridge and has a smaller surface area, making the Stinger the better choice.
Old Sep 19, 2004 | 11:45 PM
mdbennes's Avatar
mdbennes
Does the Halltech come with its own air bridge? Did you seem to notice a difference between the two airbridges?
Old Sep 19, 2004 | 11:53 PM
ACELR8N's Avatar
ACELR8N
Stinger has a higher flowing air bridge and I've recently read that there is no longer a fitament issue. I have the Blackwing, but DAVE68 has dyno runs which show the stinger gives more torque, as the two offer very close HP improvments. Check with Dave68, he is the stinger guru.
Old Sep 19, 2004 | 11:54 PM
StevieB's Avatar
StevieB
The Stinger comes with an airbridge and smooth coupler. The Stinger air bridge is much thicker in the area where it goes over the raidaitor, thus the problem with hood clearance. I have only seen a couple of people complain about having a problem with the hood closing, so I don't know what the deal is. I played around with making it work for hours to no avail. I even removed the hood liner and still couldn't use it.
wamara's Avatar
wamara
Cruise-In II Veteran
The Halltech does come with its own airbridge; in cross section it is fatter than the factory piece.
Old Sep 20, 2004 | 01:04 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
How do both of these stack up or compare to the Vararam ?
Old Sep 20, 2004 | 01:07 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Mike
I have a Blackwing but I don't notice much difference from the stock filter...maybe some but not what I was expecting
Old Sep 20, 2004 | 01:35 AM
ditty22's Avatar
ditty22
My stinger does rub no the hood felt but its not that bad though. I think 4 the money it was a great deal.
Old Sep 20, 2004 | 02:38 AM
Kevin21's Avatar
Kevin21
I just installed the Stinger last night. There is a rub issue on the hood liner but very slight on my "00. Definitely noticed a difference in performance.
Old Sep 20, 2004 | 09:09 AM
mdbennes's Avatar
mdbennes
Any pics on a HALLTECH installed? Like to see what it looks like and if someone has a picture of its hood liner and how much it rubs, that would be great too...
Old Sep 20, 2004 | 10:54 AM
Dave68's Avatar
Dave68
StevieB is correct in that he is one of the few, if not the only one to have hood issues with the tunnelbridge that comes with the Stinger-R. Halltech has sold hundreds, so the percentage is extremely low.
Both filters are very good and are probably close in flow capability, but more serious mods such as the installation of heads/cam or supercharger would give the Halltech system the advantage, since its tunnel bridge and smooth TB coupler provide a larger flow path than a Blackwing's setup, which utilizes the smaller stock tunnelbridge and accordian throttlebody coupler. Also keep in mind that these systems are similarly priced, so not many will argue that the Halltech Stinger-R represents the better bang-for-the-buck system.
I wish I could post pics, but this forum is holding them captive for the time being. However, if you go to www.corvettec5.com and look at the bottom of the page, you'll see a pic of the Stinger installed. Click on it to blow it up to viewing size.
Old Sep 20, 2004 | 11:21 AM
mdbennes's Avatar
mdbennes
Thanks Dave...
Old Sep 20, 2004 | 11:32 AM
QuikZilver's Avatar
QuikZilver
I put the Halltech on my 01 Z. Not fitment problems, doesn't touch the headliner, quality is great! From what I have read, some of the fitment issues are due to installation (pushing the air bridge up too far into the coupler) and some are just oddities out of the Bowling Green plant that can't be explained. For the money, I think the Halltech Stinger is great!!
Old Sep 20, 2004 | 12:01 PM
JeffLexie's Avatar
JeffLexie
I installed my Halltech Stinger on Friday night with no issues closing the hood at all. Thanks to Dave68 for the great install directions! I definitely noticed a quicker response time and a more aggressive SOTP feel when I got on it. I love the air sucking sound that can be heard from the filter and the lower exhaust tone too.
Old Sep 20, 2004 | 01:10 PM
Heard good things about the performance of the Stinger. I currently have the Blackwing and like it. The fitment is good, but if I had to do it all over again, I would have to give the Stinger some very serious consideration.
To HALLTECH vs BLACKWING
