Windows Sound Weird....
Old Sep 20, 2004 | 04:12 PM
mdbennes's Avatar
mdbennes
Default Windows Sound Weird....
When I open either the drivers side door or the passenger side. It only happens when the windows are completely up. When I open the door I can grab the window and jiggle it and it makes weird noise like its not tight...any info on this from others with the same problem?
Old Sep 20, 2004 | 04:52 PM
mdbennes's Avatar
mdbennes
No one else?
Old Sep 21, 2004 | 04:34 AM
MrLeadFoot's Avatar
MrLeadFoot
Doors have been slammed, and the regulators or the plastic pieces the guide the regulators need to be either adjusted or replaced. If they're anything like the C4s, my guess is they need to be replaced. Used to happen to me all the time in my C4.
Old Sep 21, 2004 | 12:18 PM
YBNORML's Avatar
YBNORML
Had a grinding noise on my 2000 coupe whenever I raise or lowered the passenger side window. Had the tech check it out and he replaced the regulator. No noise now but the window is a little slower which I can handle. Luckily, I have a GMPP warranty and it was covered. Good luck.
To Windows Sound Weird....
