Fender Vents
Old Sep 21, 2004 | 01:01 PM
VetteMan4Life's Avatar
VetteMan4Life
Default Fender Vents
Can anyone tell me how to remove the black plastic pieces inside of the fender vents?
Thanks for the help
Old Sep 21, 2004 | 01:11 PM
You need to take off the front wheels, then you have to take off the lower rear fender liner (held on with a few screws). After taking that off, you have access to the plastic insert inside the cove.
Old Sep 21, 2004 | 09:50 PM
71corv's Avatar
71corv
St. Jude Donor '08
The plastic insert is held in with 2 screws that point towards the rear of the car. The screws are the same size as those that hold the fender liner. Very easy to remove and replace.
Old Sep 22, 2004 | 12:51 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Why would you,want to remove those pieces of plastic just wondering.I use to have screens in their but took them out with out taking the wheel off if you turn the steering the right direction you can do the work with out taking the wheel off.But i am a woman and i have smaller hands then a man so i can work in smaller spaces.
Old Sep 22, 2004 | 01:55 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
7mm
To Fender Vents
