[Z06] Active handling question
thanks,
trebor
In many cases, the Active Handling will intervene so slightly that you'll hardly notice. In contrast, the 'nanny' on a Mercedes will harshly prevent most of the fun.
Also, you can put Active Handling into a competitive mode which pretty much takes it out of the way, except for the most egregious errors.
Enjoy!!
As far as your doctor friend, I doubt he let off the throttle or maybe didn't countersteer when he goosed the tail out. Just a guess, but my bet is that your Active Handling is working perfectly fine.
Check out this Fall 98 GM Press Release: http://corvetteactioncenter.com/tech...ehandling.html
He's used to his AWD Audi that understeers if anything. If you get it way out of whack, it's not going to really help all that much. I actually find it to be a nuisance on the track because I end up correcting and the car ends up correcting. I usually get into a kind of tank slapper when this happens.
X
Bill
I bought my car in May and for the first several months, it was sticking like glue around corners, then I began to get less grip and more rear end stepping out. I think it is the weather.
My experience has been that the F1 SC tires take a while to heat up, and work best in very warm temps. As the weather has cooled around here, I really have to watch the amount of "fun" I have in the turns
If you do have a malfunction, you should have received a SERVICE TCS in your DIC. You might want to check your codes through the DIC just to ensure that you don't have a TCS or A/H code set that you may have missed when it initially hit the DIC display.
Cold tires means little or no traction. Thus it is road temperature and tire temperature. Note I said road temperature not necessarily ambient air temp. If both are low fishtailing. If both are high grip.
