Codes help Please
Old Sep 25, 2004 | 01:10 AM
Bigben's Avatar
Bigben
Default Codes help Please
I have been pulling a lot of codes lately. I have
went to the web site many of you have recommended
to look up the codes and run the diagnostic. Now,
what do these mean?
Probelm 1
I am pulling C2105- I know my right front tire sensor
is bad, but am I pulling the following other codes
because of the tire sensor or somthing else?
U1016, U1064, U1096
Problem 2
Traction Control Codes
c1278 and c1281? what is going on with these?
Problem 3
P1514- TAC System MAF Performance- I have a blower is this corrected with tuning, or do I have a bad MAF?
Old Sep 25, 2004 | 04:58 AM
Richin Chicago's Avatar
Richin Chicago
what do these mean?
Probelm 1
U1016, U1064, U1096
Problem 2
Problem 3
U1016, U1064, U1096 are quite common on older C5s. I get them all the time. I understand the trigger point is too sensitive on these codes and they aren't indicative of any real problems.
You didn't mention if any of your codes have a "C" in the suffix or just an "H" A "C" indicates a current problem.
C2105 is the RF tire pressure sensor.
C1278 and C1281 are slightly different depending if you have active handling. But they both have to do with the steering postion sensor. Did you have the sterring shaft out for some reason? I haven't had this problem but I understand it is possible to put it back 180 gegrees out. Let me know if you have active handling and I will run the entire code.
Here is the information on P1514:
CIRCUIT DESCRIPTION
The PCM uses the TP, the BARO, the IAT and the engine RPM in order to calculate an expected Mass Airflow rate. The PCM compares this value to the Mass Airflow value and the speed density calculation in order to verify the proper throttle operation.
CONDITIONS FOR RUNNING THE DTC
DTCs P0601, P0602, P0604, P0606, P1515, P1516, P1517, P1518 are not set.
DTCs P1120, P1220 and P1221 are not set at the same time or DTCs P1120 and P1220 are not set at the same time.
The engine operates longer than 1 second .
The engine speed is greater than 500 RPM .
CONDITIONS FOR SETTING THE DTC
The PCM detects that the difference between the actual airflow (MAF) and the Speed Density calculated airflow is greater than expected.
All of the above conditions met for less than 1 second .
ACTION TAKEN WHEN THE DTC SETS
The PCM will illuminate the Malfunction Indicator Light (MIL) when this diagnostic runs and fails.
The Reduced Engine Power message displays on the driver's information center.
The PCM records the operating conditions at the time during which the diagnostic fails. The PCM stores this information in the Freeze Frame and/or Failure Records.
If no other TAC System DTCs are set, the TAC System operates in Reduced Engine Power mode, and this DTC will be stored. If certain TAC System DTCs are set at the same time, the TAC System either defaults to a more tightly restricted mode of operation if the TAC determines that limited safe operation is possible, or the TAC commands the engine to shut down.
CONDITIONS FOR CLEARING THE MIL/DTC
The PCM turns the MIL OFF after three consecutive drive trips during which the diagnostic runs and does not fail.
A last test failed (Current DTC) will clear when the diagnostic runs and does not fail.
A History DTC clears after forty consecutive warm-up cycles, if this or any other emission related diagnostic does not report any failures.
IMPORTANT: The clear DTC info function may have to be performed twice in order to clear a Throttle Actuator Control System DTC.
Clear the MIL/DTC information with a scan tool.
DIAGNOSTIC AIDS
IMPORTANT:
Remove any debris from the PCM/TAC module connector surfaces before servicing the PCM/TAC module. Inspect the PCM/TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM/TAC modules.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A. Using this kit prevents damage to the harness/component terminals. Refer to ousting Connector Test Adapters in Diagrams.
Inspect the throttle blade for being broken, bent, or missing.
Inspect the TP sensor for proper installation. A sensor that is mis-aligned sets this DTC.
When the TAC module detects a problem within the TAC System, more than one TAC System related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
For an Intermittent condition, refer to Symptoms. See: Diagnostic Information and Procedures\Symptoms
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table.
Physically/visually inspect the throttle body assembly and correct any problems that you observe. Manually move the throttle blade from closed to Wide Open Throttle (WOT) . You should not need to use excessive force. The throttle blade should move smoothly through the full range and should return to a slightly open position on its own.
