Cruise-Control Gremlins
Old Sep 25, 2004 | 04:52 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Default Cruise-Control Gremlins
Last week, when I tried to set the cruise control, the DIC would indicate that the speed was set at whatever speed I was going, but the car would decelerate. When it drop ~5 mph, DIC would say Disengaged. For about 10 minutes, I couldn't get cruise-control to work, then it was OK. Today, on the same section of that road, it happened all over again. I am stumped!
Old Sep 25, 2004 | 04:57 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I've learned duplicating the setting and re-enacting every step usually helps reveal the flaw. You did something different in the 10 minutes to engae the CC. BTW, I know you have to go over a certain speed to engage CC, so that <5 mph disengage wasn't abnormal. Maybe you held the "set" button longer after you thought there was a problem? I've experienced the same thing ... just wasn't holding the button long enough. Just my .02 ... and besides, I'm giving you a reason to go for a drive! Just use a different road ... sounds like someones messin' around with a Cruise Control Jammer on that other road you were on.
Old Sep 25, 2004 | 11:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the vacuum hoses that connect the CC unit to the manifold. If they are cracked or loose the Cruise will not work properly.
BC
To Cruise-Control Gremlins
