killed my optima red top
Old Sep 27, 2004 | 02:08 PM
FallenWhun's Avatar
FallenWhun
Default killed my optima red top
My stupid azz left my key turned in the ignition for 2 days and now my optima is dead. when i disconnected the negative terminal there were some sparks and my head lights came up for some odd reason. Did i mess up something? in addition to that i dropped the terminal screw into the abyss under the battery and now I can't find it.
Right now I'm charging it and any ideas how much damage i've done to my car and the battery itself?
Old Sep 27, 2004 | 02:26 PM
FallenWhun's Avatar
FallenWhun
how do these batteries hold up with charging em? should I recharge it or throw it away and burn a new hole in my wallet?
Old Sep 27, 2004 | 02:33 PM
C54TIM's Avatar
C54TIM
Just charge it like you normally would charge any battery. Then reconnect all the cables. Take the car out for a nice long spin, an hour or more.
It should be fine.
Cheers,
Tim
Old Sep 27, 2004 | 02:39 PM
Patches's Avatar
Patches
You should be fine. The Red Top is pretty resilient so, if you're able to charge it sufficiently to get the car started with it, the battery is most likely in good shape.
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Mine has been completely discharged more than once due an electrical problem I once had.
Charged up fine everytime and still going strong after a year of use.
Dale RED 98's Avatar
Dale RED 98
Mine has been dead a few times and a good charge was the anwser. Give it a slow charge and it should be fine. Good luck!
Old Sep 27, 2004 | 02:42 PM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
Ok...since no one has asked...... What was the key doing in the car?? Why was it turned to the ON position????
Old Sep 27, 2004 | 02:50 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
[QUOTE=FallenWhun] in addition to that i dropped the terminal screw into the abyss under the battery and now I can't find it.
[QUOTE]I would suggest you find that screw - there are lots of nasty things it could short out on down there. Maybe you could go 'fishing' for it with a magnet...
Old Sep 27, 2004 | 03:02 PM
Fuelie driver's Avatar
Fuelie driver
I suggest you remove the battery! then you can remove the battery tray, which will give you access to the abyss so you can find the terminal screw!! If this doesnt work you can remove the tire and the panel in the wheel well, this will also give you access to the abyss
Old Sep 27, 2004 | 03:10 PM
Baetke's Avatar
Baetke
Don't feel like the Lone Ranger, I did the same thing to my car last week. Left it sit for four days before I noticed the key on.
Old Sep 27, 2004 | 03:14 PM
lvvette777's Avatar
lvvette777
Draining the battery all the way down and charging it up will not harm it one bit. Just make sure you charge it all the way or your battery will develop a "memory" of the weaker charge. It will never hold more than that much juice again.
You, your battery, and your car will be fine!!!!!
Old Sep 27, 2004 | 04:35 PM
RCK1999's Avatar
RCK1999
[QUOTE=ptdrummer54][QUOTE=FallenWhun] in addition to that i dropped the terminal screw into the abyss under the battery and now I can't find it.
Sounds good, except for the magnet thing. Computer chips, circuits and electronics don't like magnets!
Old Sep 27, 2004 | 06:03 PM
You should be able to just recharge the battery and be fine. Probably didn't do any damage. Take it out for a nice drive often to keep it well charged.
Old Sep 27, 2004 | 06:18 PM
ooh yeah's Avatar
ooh yeah
Those batteries have a 3 year free replacement!! go get another and to hell with charging it.
Old Sep 27, 2004 | 10:41 PM
FallenWhun's Avatar
FallenWhun
Default Thanks
Thanks all for the feed back. I charged the battery and its practically good as new but it left a lot of history codes on the DIC.
I left it on, on accident because I was rushing home upon receiving a call from my bro that my mom was in diabetic shock. So during those two days I was in the hospital keeping my mom company.
Thanks for the replies I was a little bit worried there that I might have screwed my car/battery up, but I was even more worried about what was happening to my momma.
Old Sep 27, 2004 | 11:25 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Well I certainly hope that your Mom is OK! And all the replies were right on. Good luck to you and your Mom.
Old Sep 28, 2004 | 09:47 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
No political slogans allowed!!!This about Corvettes
To killed my optima red top
Old Sep 29, 2004 | 06:31 AM
Blue Lion's Avatar
Blue Lion
When I installed my Optima recently, I dropped a screw also. My friend had a magnet that looked like a portable radio or old cordless phone antenna. I used this to go straight down below the battery and catch the screw. I'm sure these aren't new items, but my garage is pretty spartan and I'd never seen one.
Good luck with your Mom...compared to the battery that's the important issue.
Old Sep 29, 2004 | 07:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The codes that you saw after you got your battery back to life were because the computer modules stop functioning properly when they drop below 9 VDC. Once the battery is properly charged, clear the codes and you should be god to go!
Did you ever find the terminal screw?? If not I would recommend removing the battery and searching and or removing the removable access panel behind the passengers front tire and taking a look.
BC
Old Sep 29, 2004 | 10:36 PM
FallenWhun's Avatar
FallenWhun
I went out and bought a new screw but i do plan on taking out the passenger side wheel to look for it. I didn't want to use a magnet because I was told that I could screw up the computer.
Any possiblities of it falling out or staying in there and screwing something else up?
