Hide a key???
Old Sep 28, 2004 | 07:34 PM
Gib's Avatar
Gib
Default Hide a key???
I have a '01 Vert and am looking for ideas on where to hide a key. Keeping a key in my wallet is a pain. I have a magnetic box that I can use or am open to other ideas. Where can a magnetic box be hidden or any other ideas?
Appreciate the help. Thanks, Gib
Old Sep 28, 2004 | 07:40 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Being a plastic car that's kind of tough. You could go underneath and attach it to the frame.
jrose7004's Avatar
jrose7004
Thats it!
Old Sep 28, 2004 | 07:41 PM
Dilligas's Avatar
Dilligas
I have always taped a spare to the back of my license plate, it may be a little bit of a hassle to get the plate off but it is better than not getting into your car.
Old Sep 28, 2004 | 08:50 PM
JoesC5's Avatar
JoesC5
Several years after purchasing my 98, GM sent me an emerg key that has no pellet or thick plastic handle. Made for carrying in your wallet. Since it won't start the car(only unlock the door) I have a pellet equiped key hidden under the hood in a place where no one would look (not the easiest to get to) but it's for an emerg and I've never had to use it. Have Wal Mart cut you a key witout the pellet and remove the thick plastic handle and follow suit.
Old Sep 28, 2004 | 09:20 PM
Gray Fox's Avatar
Gray Fox
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
I take it you get to it from underneath the car???
Old Sep 28, 2004 | 09:49 PM
alanh's Avatar
alanh
I have a regular key outside in a magnetic box. It took just a little installation work but I attached a small steel plate, large enough for the magnetic key holder, in an area you can't see but can get to with your hand and I don't have to get down on the ground, just in case the weather is bad. I have outside keys on all my vehicles and with the electric locks being so easy to accidently hit, (been there, done that) it gives me peace of mind.
Old Sep 28, 2004 | 09:57 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
What is your address again?
Old Sep 28, 2004 | 11:48 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I would maybe get some Industrial Strength Velcro and find a decent place to stick it ... I mean the Hide-A-Key box silly! Make sure you check it once in a while, just remind yourself you have it and that it's still there!
Old Sep 29, 2004 | 12:03 AM
jeff1surfs's Avatar
jeff1surfs
thanks for the tip! I'll get it done 2morrow.
Old Sep 29, 2004 | 12:04 AM
PaceThis's Avatar
PaceThis
You guys have got to be kidding me...I wouldn't tell if I had one hidden...
Old Sep 29, 2004 | 12:12 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
I hope I dont' see anybody looking up under my car tomorrow...
Old Sep 29, 2004 | 08:08 AM
NewfieC5's Avatar
NewfieC5
The gentleman with the year, color, state, city, ZIP, name and key location posted on a public forum may want to find a new hiding spot!
Old Sep 29, 2004 | 08:15 AM
bsmith's Avatar
bsmith
the small keys GM sends you are small enough that you can actually put them in your wallet.
If you decide to stick a hide-1-key under your car, make sure you put it some place that it isnt going to be knocked off because of the low clearance of your car
or you could just use the passive feature
Old Sep 29, 2004 | 08:25 AM
Miaugi's Avatar
Miaugi
Here's a tip, go to your dealer and get a Cavalier key (about $2), it is a match for a Vette key (without the security pellet). Get this key cut to your Vette key and hide that one outside your car, if anyone finds it they still can't start the car (of course you'll have to hide a regular key inside the car too). The Cavalier is also easier to hide and if it's lost, you're not out $40.
Old Sep 29, 2004 | 09:15 AM
IM QUIKR's Avatar
IM QUIKR
I had my license plates stolen once. Boy i'd have been sorry with that placement.
The gills have a flexible flap inside. Behind that flap is a steel cross bar for fender support. A magnetic box could sit there and never be seen or found. Plus, the area below is enclosed so if it falls off it won't be lost on the street. 9 hex screws will remove the access panel in the case it does fall off.
Old Sep 29, 2004 | 10:22 AM
OneBadGix's Avatar
OneBadGix
I'm confused.
Why would you need to hide a spare key for your vette or any car for that matter? Can you be that forgetful that it happens enough that you need to result to such a measure?
To Hide a key???
Old Sep 29, 2004 | 10:23 AM
JoesC5's Avatar
JoesC5
No, I take the emerg key from my wallet and open the door. I then open the hood using the release under the dash. Then I retrieve the key from it's hidden location in the engine compartment. I then take the key I just retrieved from it's hidden location and insert it in the ignition. Simple, isn't it? You can also hide the key in the cargo area or in the front cockpit area if you don't want to open the hood.
Old Sep 29, 2004 | 01:31 PM
Doo's Avatar
Doo
St. Jude Donor '03 & '06
Put a key in a wheel center cap
Old Sep 29, 2004 | 02:49 PM
xwing's Avatar
xwing
I would worry about the key falling off while driving.
