C5 FAQs?
Old Sep 28, 2004 | 09:53 PM
PopolZ's Avatar
PopolZ
Default C5 FAQs?
Hey guys,
I'm looking to buy a C5 next spring/summer and I have alot of questions
I did lots of research on the forum (and other vette forums). Some threads did answer a few of them but i'm looking for a FAQ (frequently asked questions) so I don't have to ask 1928190281928591 newbie questions.
Thanks,
Alex
Old Sep 28, 2004 | 10:04 PM
johneboy's Avatar
johneboy
the button to open the gas cap is inside the center console
boy did i feel like a fool at the gas station....
Old Sep 28, 2004 | 10:06 PM
Matt69-ZO6's Avatar
Matt69-ZO6
He}}, I still forget after 13,000 miles!
Old Sep 28, 2004 | 10:12 PM
ACELR8N's Avatar
ACELR8N
That's a good idea for the Forum. But, then you would never have the joy of posting questions, regardless of how dumb, and seeing the response you get from so many great folks helping out. While FAQ might help newbees, the sense of community here is what it's really all about. Good luck hunting.
Old Sep 28, 2004 | 10:15 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I've read on here of folks being "spanked" by the panel as it opens.
Old Sep 28, 2004 | 10:17 PM
Stickman81's Avatar
Stickman81
Originally Posted by PopolZ
Hey guys,
Thanks,
Alex
Welcome. You have come to the right place to get loads of information on the best car. Best of luck with your search. Hang in there and get what you want in the car. I had fun searching, but last week I had the most fun driving my own "new" Corvette home.
Old Sep 28, 2004 | 11:19 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
I remember that day well. picked the car up from Savannah, GA, driving back to DC. Get off to fill up and can't find the release button... Sitting at the station with the owners manual
Old Sep 28, 2004 | 11:39 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Welcome to the forum with the greatest people on the Earth! If you dont ask "1928190281928591 newbie questions" how are we supposed to learn anything? Hope you have fun here! and don't forget to wave!
Here's a list of some things you may get some kicks out of:
1. Some 2000-2001 C5 had an oil consumption problem due to bad rings.
This had something to do with light tension oil control rings and when way the person drove his car. High RPM and light load combinations. This caused ring flutter and excessive oil usage.
2. Rear end output shaft seal leaks.
3. Clutch slippage. If the car was run hard it will need to be replaced!
4. Steering wheel column lock problems. Column lock bypass kit will fix the problem around $45-50. Bucks if it is not already installed.
5. Battery acid leak problems from original AC Delco battery. Destroys wiring harness, PCM and vacuum lines under the battery. Costly!!!
6. Wet carpets due to AC air box drains plugging up.
7. Windshield cowl drains clogging up causing wiper motor to fail! Easy fix if you catch it prior to destroying the wiper motor!!!
8. Drivers seat tracks wear causing the seat to rock when you accelerate or brake.
9. Emergency flasher switch failure. Expensive part! Very expensive labor to replace it!!
10. Right and left door control electronic module failures.
11. Head light motor (stripped plastic driven gear) "just like the C4"). Same fix, replace with brass!
12. Tire pressure sensor module failures.
13. Head light motor control module failures.
14. Driver seat leather wear on the seat back outboard bolsters.
15. There are ways that you can check to see what service and or repairs have been done to most cars.
16. Ask for help ... no matter what ...chances are it's already happened to someone else!
Old Sep 29, 2004 | 05:49 AM
photocopy's Avatar
photocopy
This was the first thing they showed me at Les Stanford. Apparently, some people had had some issues.
Old Sep 29, 2004 | 08:59 AM
Lancer033's Avatar
Lancer033
if you look at that list, it's a wonder that any of us even fool with these pieces of junk. Although I've heard of most of those probelms and delt with several of them myself, that's the largest list of "common C5 problems" i've seen
Old Sep 29, 2004 | 10:04 AM
Richin Chicago's Avatar
Richin Chicago
Hey guys,
Thanks,
Alex
http://www.jakelatham.com/c5/misc/faq.shtml#1-12
Old Sep 29, 2004 | 12:07 PM
Snackbar's Avatar
Snackbar
Lots of problems from the dual zone climate control.
Old Sep 29, 2004 | 12:12 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Guys, he asked for C5 faqs, not 101 reasons not to buy a vette!
Old Sep 29, 2004 | 12:15 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Very Helpful Website for Stats and Info:
http://www.idavette.net/
Old Sep 29, 2004 | 12:24 PM
Antonio BananaS's Avatar
Antonio BananaS
and we are talking about msrp of 57,850(04 convertible) that comes with all the above. on top of that, we have the mighty mighty GM service ethics and quality that stands out from the rest of auto makers.
imo, everyone MUST hang out here for at least three months before making the purchase decision.
one last thing, i would've still bought a corvette even if i knew all the above already because i'm stupid obssessed corvette nut.
why wait? just go buy one now and let the friends here fix all the little problems for ya!
Old Sep 29, 2004 | 01:12 PM
Antonio BananaS
Hey guys,
Thanks,
Alex
Fahhken Annoying Questions you have to ask about Corvette
1. Is there a dealer with good service department?
NO! sorry
2. Did GM ever fixed the squeek and rattle problem after 2002?
NO! don't believe the hype
3. Are the seats real leather?
NO! don't expect too much
4. Is the resale value reasonable among its class?
NO! r u kidding?
5. Is there any single female owner in the forum?
hell NO!
6. Is that a cup holder by the gear box?
NO! duh~ it's a shot glass holder
7. Does it really pull close to 1G as a stock model with the run flat tires?
NO! try it if you hate living
8. Does factory touch up paint color match?
NO! but it will make the scratches stand out
9. Does the dual zone climate control work?
NO! don't even try unless you want the heater on the passenger side
10. If you can do it all over again, would you still buy a Corvette?
HELL YEAH!!! don't ask why
Old Sep 29, 2004 | 03:51 PM
GOZ2FST's Avatar
GOZ2FST
NO! sorry
NO! r u kidding?
hell NO!
THAT'S HILARIOUS AND TRUE...
To C5 FAQs?
Old Sep 29, 2004 | 04:08 PM
PopolZ's Avatar
PopolZ
Thanks for the answers guys!!!!
I'll read those sites and keep the useful info you posted!
Antonio BananaS: that's hillarious
but GM can't be as bad as Chrysler... at least I hope not...
Old Sep 29, 2004 | 04:13 PM
Antonio BananaS
oh yeah, and check this out for more info http://forums.corvetteforum.com/show...1&page=1&pp=20
Old Sep 29, 2004 | 05:51 PM
Post away. Doing a search may help some, but at times you just have to ask. That is what many people are here for - to share the knowledge gained by either experience or asking the same questions.
