Seat removal
Old Sep 30, 2004 | 04:33 PM
MisterC's Avatar
MisterC
Default Seat removal
Has anyone removed their seats? Can you give me some advice/direction about removing the seats?
Thanks,
Old Sep 30, 2004 | 05:08 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
go to www.vetteessentials.com look for seat install removal instructions
http://www.vetteessentials.com/instr...er_change.html
Old Sep 30, 2004 | 05:38 PM
Only four bolts hold the seats in (the two in the front are covered by a plastic trim piece). Loosen the four bolts (I believe a #10 socket is needed) and then you need to lift up the front of the seat and disconnect the electrial connections. Once that is done, move your steering all the way up, and lift the seats out of the car. You will need to bring the seat back forward to get it out of the car. I would suggest putting a towel or blanket down on the sill area to prevent any scratching. Good luck.
Old Sep 30, 2004 | 07:50 PM
Purerock105's Avatar
Purerock105
4-bolts and disconnect the power cord and just lift them out.
Will take all of 10-minutes.
Why are you removing the seats...?
Old Sep 30, 2004 | 07:57 PM
noran01's Avatar
noran01
Ya, its VERY easy!
Old Sep 30, 2004 | 08:48 PM
MisterC's Avatar
MisterC
Thanks for all the tips, guys. I'm removing them because I've got costom seat covers coming and I'd rather take the seats to the upholsterer than the whole car.
Old Sep 30, 2004 | 10:29 PM
Purerock105
Yes. Will be much easier to install them with the seat out, plus you
can vacuum all the crud from underneath the seat. No matter how
clean you are, there is ALWAYS something under the seat.
To Seat removal
