Active handling system
Old Sep 30, 2004 | 10:16 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default Active handling system
I wonder if the people on the forum that have this system keep it on or off?I have had my car for almost a year and i hit the button by mistake today and found it had not been on all this time the manual tells me it should be on all the time what do you the people on the forum think on or off..........................Thank you Charlene
Old Sep 30, 2004 | 10:17 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Unless I was to do "competitive driving" in which I would hold the button down and put it in that mode, I would leave it alone.... especially when it rains. Nothing like a little extra help in the control department.
Mark
Old Sep 30, 2004 | 10:23 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I believe you'll find your AH is on unless you turn it off. When you press the button your DIC will tell you whether or not it is on and you'll get a light on your dash.
Old Sep 30, 2004 | 10:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
It is on by default every time you start the car...unless you press the button after startup to turn it off.
The amber light in the instrument cluster indicates it's off, not on.
I would suggest doing nothing, and leaving it on all the time.
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Whenever you start your car it is automatically on.
I would keep it on unless is was doing an autocross then I go into comp mode.
There has been to many stories on the forum where someone has it turned off and crash the car.
just my .02
Z06-JIM's Avatar
Z06-JIM
Mark
The only time I take mine out of active handling mode is at the track and an occasional tire barking, spirited driving on the street.
Then I use the competitive driving mode mentioned above.
Old Sep 30, 2004 | 10:32 PM
Davesredvette's Avatar
Davesredvette
Default state is ON. Turn it off and you can slip and slide at will. 3rd mode is comp mode, hold button down for 20secs and you can access this mode. Usually leave it alone, ON unless I'm feeling frisky, then comp mode. Comp mode allows you to get a little loose without totally throwing it away. I never turn it off, not a good enough racer yet!!!
Old Sep 30, 2004 | 11:40 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Charlene - I consider myself a pretty competent driver, and except for one time - l've left the button alone. As everyone has already said - it defaults to ON everytime you start the engine. You;ll see the amber light with the symboll showing the back of a Vette and two "Patches" (just like the Man's avatar - How many of you noticed that B.T.W.?).
350 HP (gross) can very unexpectedly get you into trouble quick if you aren't paying attention, on the wrong road surface (wet, gravel ,etc.).
My vote is leave it alone unless you're on the track!
Old Sep 30, 2004 | 11:48 PM
StevieB's Avatar
StevieB
I turn it off if I want to get max power, ONLY while going in a straight line. Traction control will cut power if it senses wheel spin.
Old Oct 1, 2004 | 12:08 AM
Bill Dearborn's Avatar
Bill Dearborn
Sometimes TC will cut power with wheel spin. Other times it just applies the brakes. Its first action is to apply brakes unless it sees parameters that cause it to both hit the brakes and cut power.
As for Competition Mode it can perform neat tricks if you want to play and can keep you out of trouble a lot of times.
Bill
Old Oct 1, 2004 | 09:15 AM
charlene's Avatar
charlene
i guess i will have to look for the back of the vette and the two patches i really never paid attention to that on the dash.Thank you
To Active handling system
