[Z06] allkar or vettethret (coilover ?)
Old Oct 1, 2004 | 10:48 AM
SupraEater's Avatar
SupraEater
Default allkar or vettethret (coilover ?)
quick question for either of you guys. i am about to buy a set of coil overs. i know other cars but i am not too sure about the corvette sus lay out. if i get the coilovers (threaded shock and spring combo)...do i need anything else to make the kit work or will it bolt right up? i was contemplating on just cutting the bushings and lower rear bolts...but i would rather have more adjustability options. also will the camber adjust fairly easily or is there a camber correction kit i should get? thanks in advance.
Old Oct 1, 2004 | 02:20 PM
vettethret's Avatar
vettethret
They are a complete bolt in so you wont have to get anything else. Just have it aligned and you can pic what alignment specs you want. If you are going very low make sure you get the shock bodies shortened at least 1.5" so you will get some travel back! Depending how low again I would get the baer bump steer kit that corrects suspension geometry. Other than that they are a true bolt in so nothing special is needed. Good luck, you'll love em.
Old Oct 1, 2004 | 03:29 PM
SupraEater's Avatar
SupraEater
thanks....snow coming in a couple months and i need a high horsepower snow plow
Old Oct 1, 2004 | 05:03 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
, The New set from WCC is SWEET!!!
Old Oct 1, 2004 | 06:03 PM
vettethret's Avatar
vettethret
WERD.........
Old Oct 2, 2004 | 05:25 PM
mmorse's Avatar
mmorse
vettethret,
I know you got your car tuned at LAPD. Now that you've run it awhile, what do you think? Any issues? Was it worth it? I'm thinking of doing it. Just wanted your feedback first.
thanks
mark
To allkar or vettethret (coilover ?)
