Breathless Shifter Installed....
Old Oct 2, 2004 | 10:47 PM
Matt69-ZO6's Avatar
Matt69-ZO6
Default Breathless Shifter Installed....
Thanks to QuikZilver's bum shoulder, I was able to install the Breathless shifter in my Z06. It took about 30 minutes and would have been well worth if it took all day.
The shifts are nice and concise - 1 to 4 are very easy to find, fifth and six are O.K - no worse than stock. Downshifting is greatly improved over the stock and hurst shifter. IMHO!
The shifter has the softest springs installed (doubt you'd want it much stiffer unless you are an ox!). Even my wife thought the shifter was just fine to shift (Darn it!).
The BPP shifter costs a bit more, but I would generally say it is worth it based upon my use of a stock shifter, hurst shifter and the BPP.
Thanks again to QuikZilver for the shifter....
Old Oct 2, 2004 | 11:00 PM
USA-VET's Avatar
USA-VET
Old Oct 2, 2004 | 11:28 PM
Matt69-ZO6's Avatar
Matt69-ZO6
http://www.z06vette.com/reviews.php
Good enough?!
Old Oct 2, 2004 | 11:36 PM
Old Oct 2, 2004 | 11:44 PM
Dave68's Avatar
Dave68
I've seen quite a few comments from those who have tried both the Hurst and the BPP, all recommending the BPP over the Hurst. I'm beginning to steer in that direction, although I did see one description of a short boot that indicated that it fits all short-throw shifters except BPP.
Did you install a short-boot? If so, from where did you purchase it?
Old Oct 2, 2004 | 11:51 PM
C'ing-Red01's Avatar
C'ing-Red01
I'm Telling
Old Oct 2, 2004 | 11:57 PM
Matt69-ZO6's Avatar
Matt69-ZO6
I did buy the short boot from QuikZilvr, but I didn't install it. I still have the stock one in and it fits very well....go figure!
I do have a stock shifter ****, maybe other ***** need the shorter boot, but I doubt it..
Here is a photo of the shifter in 1st:
Old Oct 3, 2004 | 12:02 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
I like mine!!!
Got any rattle?
Old Oct 3, 2004 | 12:05 AM
Matt69-ZO6's Avatar
Matt69-ZO6
Originally Posted by ALLKAR
I like mine!!!
Got any rattle?
MUCH less rattle than with the hurst, maybe a bit more than stock - but that is what the Stinger's (soon to be B&B Bullet's) are for!
Old Oct 3, 2004 | 12:09 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
I did the tennis ball mod and it took care of most of the rattle.
B&Bs????
Old Oct 3, 2004 | 10:25 PM
Dave68's Avatar
Dave68
A couple more questions: Did you purposely choose the angled (forward or backward) version or do you have this one because it was a good deal? I've seen the straight version going for $207. Is that a decent price?
Old Oct 3, 2004 | 10:32 PM
Matt69-ZO6's Avatar
Matt69-ZO6
Yes and Yes. For me, I wanted the angle. It puts the shifter over and closer to you and allows you to line the shifter up to your arm/shoulder , not lining yourself up to the shifter. Its just my preference, but I sure like it!
Seems like the biggest downfall to some of the aftermarket shifters is spirited/road course downshifting. The angled shaft of the BPP shifter makes for a great road course shifter.
If you notice the previous post, it shows the shifter in first gear. Hope it helps...
Old Oct 3, 2004 | 11:37 PM
VetteHunting's Avatar
VetteHunting
hmm.....yours sits a LOT lower than mine does. This is a pic of mine with the stock boot as well....In first.....
Wonder why that is??? My throw is really short, but the shifter itself doesnt look like Matts. Any ideas?
Old Oct 3, 2004 | 11:45 PM
Matt69-ZO6's Avatar
Matt69-ZO6
Hmm?? Maybe it's just camera angle? I have a very busy day at work, but I will measure the distance from the console to the top of the shifter...
Old Oct 3, 2004 | 11:53 PM
Dave68's Avatar
Dave68
...good points - now I'm leaning toward the angled version! By the way, I'll bet the difference in height between yours and Vettehunting's shifter setups is because of the *****. The ball may not be threaded as deeply as the OEM ****.
Old Oct 4, 2004 | 09:49 AM
QuikZilver's Avatar
QuikZilver
Matt69-Z06...Glad you really like the shifter. I thought it was great, but this d@mn shoulder couldn't take even the softest springs.
For all to know: I ordered this shifter direct from BPP (they give forum members a 10% discount). The short boot was ordered from Nate at the Corvette Garage and is a Vette Essentials boot. The shifter was ordered with the angled handle.
If you do not have a major shoulder injury, this is a great shifter. I had virtually no noise vibration from it. My only recommendation is that you do not use the bolts that BPP includes. Go out and get 4 grade 5 or higher bolts. The bolts that were included were not graded. I snapped one when I was torquing it down.
Difference between Vettehuntings and Matt's could be that Vettehunting has a straight handle or the set of holes that the handle was mounted to. When I put it together (don't know if Matt changed this), I had the handle mounted in the front holes to shift the handle back.
Again, Matt...thank you very much for the smooth transaction. I am sorry it took me a couple extra days to get it shipped (I hate hurricanes!!!), thanks for being patient with me.
Neil
Old Oct 4, 2004 | 10:45 AM
Matt69-ZO6's Avatar
Matt69-ZO6
I changed the handle all around and ended up back at your setting!
Old Oct 4, 2004 | 01:09 PM
VetteHunting
Well, I have the angled shifter, and I have it mounted so that it brings it back to me as much as it could. Who knows....
I'm more than happy with mine, and Matt is more than happy with his. That is what matters. Great job Breathless
To Breathless Shifter Installed....
