Question Rhino Ramps
Old Oct 3, 2004 | 11:04 AM
VLVETTE's Avatar
VLVETTE
Default Question Rhino Ramps
I can back up on to the ramps no problem but when I try to pull the front end up on to them they slide away. The rubber blocks are on the bottom of them my garage floor is concrete. Any suggestions?
Old Oct 3, 2004 | 11:08 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Same problem for me too! I fixed this by putting them atop a couple of old bathroom carpets with the rubbery like no skid stuff on the bottom
Old Oct 3, 2004 | 11:12 AM
Patches's Avatar
Patches
Even new sometimes, the ramps want to slide on slick concrete. I use a couple of old towels and make sure the tires are completely on the towels before the start climbing the ramps. That way, they grip the towels and ramps at the same time and there is no realative motion between them.
Old Oct 3, 2004 | 11:14 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
I use the same trick, works like a champ
One more thing for the wife to roll her eyes at
Old Oct 3, 2004 | 12:33 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Probably the best idea I have seen on here concerning that issue was to drill a hole at the base of the ramp and tie a 2 foot rope or so to it so as you drive up the ramp, the rope is under the tire and keeps the ramps from sliding. Pretty genious physics to me although I haven't tried it yet but make sense and some have done it with good results. Good luck.
Jim kay
Old Oct 3, 2004 | 12:42 PM
Larry_Yerton's Avatar
Larry_Yerton
I have a big piece of indoor/outdoor carpeting that I unroll. No slipage and it's nice to lay on also.
Old Oct 4, 2004 | 08:59 AM
FASST LN's Avatar
FASST LN
Do any of you hit your front air dam (the rubber parts in front of the front wheels) when trying to drive up onto the rhino ramps? I don't think my car is lowered, but this has been a problem. Just curious to know if this is normal?
Thank you,
Old Oct 4, 2004 | 09:05 AM
Ron H's Avatar
Ron H
Thank you,
It is normal. The airdam is designed to bend.
Old Oct 4, 2004 | 10:26 AM
Wah's Avatar
Wah
Make sure you are not pressing the brake pedal while climbing up, however lightly. If your car is automatic, you may have been doing this. It may help to wait until the engine is fully warmed up so it's not at high idle.
Old Oct 4, 2004 | 10:29 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I just take a big run at them...
Old Oct 4, 2004 | 10:36 AM
Dave68's Avatar
Dave68
I use a welcome mat under the rear of each and yes, the air dam scrapes along. Now that my car is lowered, I do need a "pre-ramp", so I'll be making something soon (for my annual oil change).
Old Oct 4, 2004 | 10:42 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Only the center section, I think there is some overlap from the side pieces in front of the tires that may be permanently damaged. I need to look closer to be sure though.
Old Oct 4, 2004 | 12:42 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
No sliding here on my garage floor. I take the ramps and slide them up to the wheels (like you were putting in a wheel chock(sp?)) and then I drive right up. Maybe just the added resistance of the pressure from the wheel or the air damn helps to hold mine in place. As far as rubbing...yep, mine too.
Paul
Old Oct 4, 2004 | 01:01 PM
gwanghoops's Avatar
gwanghoops
i place them right in front of the tires and kick the ramps hard to act like a wedge.
PDXBigMan's Avatar
PDXBigMan
I got a couple pieces of that rubberized waffle textured shelf liner and place the ramps on them, no problem with sliding on my exposed aggregate driveway. Lightweight, I roll them up and store them inside the ramps, and they are waterproof (I sometimes put the Coupe on ramps to make the nose easier to wash).
Old Oct 4, 2004 | 01:23 PM
VlackBette's Avatar
VlackBette
my car is lowered, plus I don't feel comfortable driving onto the ramps... so I just jack up the car and lower it on the ramps...
Old Oct 4, 2004 | 01:32 PM
The piece of carpet works well for keeping the ramps from moving.
Old Oct 4, 2004 | 02:39 PM
jo8243's Avatar
jo8243
The anti-slip stuff that is designed to go under a rug (to keep the rug from moving) works for me. You can get a roll of it at home depot/lowes.
Old Oct 4, 2004 | 02:48 PM
Angella's Avatar
Angella
I put my brother in front of one, and the boyfriend in front of the other, and just gun it
Works great - on all of our cars EXCEPT the Cherokee... I put it in 4wheel, and still sometimes drive over the darn things... I don't even know why I bother
To Question Rhino Ramps
