Paint Question
Old Oct 3, 2004 | 07:11 PM
J1963D's Avatar
J1963D
Default Paint Question
Hi, I have a 2004 coupe and a 1963 FI coupe.
But my question is on the 04. I take very good care of
my cars. Driving the new coupe I always hold back by 4 or 5
car lengths But looking at the front of the car, I have little
paint chips.
Looks like just the clear coat. I have been told
I have a problem with my clear coat. The car is millenium yellow.
Is this a paint problem or normal. If normal would you recommend
a Mask or Bras. What is the best available ?
Thank You
Old Oct 3, 2004 | 07:17 PM
JCR_Indy's Avatar
JCR_Indy
Wonder if the color has anything to do with this? I have an '04 Sprial Gray and I don't have any chip-spots on mine. I too, stay far away from the cars in front - so just wondering..
I've had mine for over 4 months and have 1500+ miles, so maybe you drive it more than I do..
Just a thought..
JCR_Indy
Old Oct 3, 2004 | 07:54 PM
EatRice's Avatar
EatRice
I have had alot of chips in the nose of my 99. Had it painted already. I am going to get a clear bra for it.
Old Oct 3, 2004 | 08:35 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
Does it look anything like this?
I'd have it looked at. I've done some serious road tripping and don't have the issues you're describing.
Old Oct 3, 2004 | 08:40 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
WellAdjusted,
I am calling 1-800-FOR-AVETTE. I can't believe you allowed such an abundant amount of bug splatter on your car. What are you thinking? They have classes for this in case you need help.
Old Oct 3, 2004 | 08:52 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
J,
The chips or spots you are seeing are similiar to when you look at a windshield from the inside and the glass is "peppered" with stone chips.
What you are seeing is tiny gouges in the clear coat. Get enough of them and it looks like the paint is ready to flake.
Driving behind helps but think about this. You're driving roughly 60 into the opposite direction of the stops and debris coming back. Though the car in front of you is running 60 also, the wheels are turning probably double that. Whipping a pepple or debris back at that speed into a car coming at 60 would be like throwing a rock at a stopped bumper cover at almost 200 mph.
Well, you got the point... back to your question. I would use a bra or mask only for trips if you have to use one. The paint on your car is basecoat/clearcoat and when the clearcoat receives the constant pressure and rubbing from a bra, it will scratch the clearcoat leaving you with a dull, unpolished look.
There are companies that use computer die-cut 14 mil thick clear vinyl to place on the front (kind of like a see through bra) but to be honest, I'm against that too. (edges to thick, start to look dirty and get wax buildup on the edges)
HTH's,
Mark
Old Oct 3, 2004 | 09:42 PM
Drive the car, you will ultimately get the chips you describe. Not so sure it is a problem with the clear coat. You can either get a bra or something like Cleartastic for the front end. I run a GM bra and it keeps many of the chips off. And, after more than three years of running the bra, it has not damaged the paint.
To Paint Question
