odometer question
Old Oct 4, 2004 | 02:58 PM
98SilverVette's Avatar
98SilverVette
Default odometer question
Hope this is in the right forum, I was going to post it in tech but it said engine only
Im looking to install a HUD in my 98, and that would involve a custer swap. If the new cluster has a differnt odometer reading - is there any way to sync the new cluster with my computer so my mileage would be correct? id hate to get a cluster that says 90k miles when my vette really only has 28k
Old Oct 4, 2004 | 04:41 PM
pk2401's Avatar
pk2401
St. Jude Contributor
Since the odometer is a digital read out and not a rolling clock, I think the mileage would be kept in the car's computer. Of course I'm just assuming. But I've read lots of posts of people doing this with no problems, so I don't think you will.
Old Oct 4, 2004 | 05:55 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
To begin with----the mileage is stored in the large green printed circuit board located in the instrument cluster. The PCM or any other computer does NOT store mileage.
All you have to do is: Take the instrument cluster to a speedo shop that can change the mileage on the cluster odometer. Tell them what you want the new mileage set to and you're good to go. They should have you sign some State Odometer Form stating what you are changing the odometer to.
This is exactly what I did when I installed a HUD in my 1998 Coupe. I had a 2000 IC w/ 47312 miles which was changed to 17000 miles (the current mileage of my '98). It works great--absolutely no problem at all. The shop that changed my IC took 30 minutes and charged me $80. Good luck.
Old Oct 26, 2004 | 01:21 PM
98SilverVette
thanks for the help everyone, I called around and no one in the area can do this Is it something I can do myself? Ive posted in every memphis area board I can think of with no luck!
(sorry for bringing back an old topic)
Old Oct 26, 2004 | 07:30 PM
98SilverVette
ttt
Old Oct 27, 2004 | 07:29 AM
BiggieBoy's Avatar
BiggieBoy
No---you cannot reset your odometer yourself. Special equipment is required.
Here is the info on the shop that reset my odometer. Give them a call.
AJR International
951 N. Larch
Elmhurst, IL 60126
800-232-3965 630-832-0222
This is a 50+ year old Chicagoland speedometer/radio shop. They've been around a long time and do good work. AJR charged me $80.00 plus $5.60 IL state tax. Good luck.....
To odometer question
