Low Oil Level
Old Oct 4, 2004 | 04:52 PM
VinnyG's Avatar
VinnyG
Default Low Oil Level
On a trip to the Central California Coast over the weekend I had a "Low Oil Level" message show up on my DIC. I stopped at a Mobil station and sure enough I was approx. 3/4 of a quart low. I topped it off and hit the rest button but the message keeps popping back up. Is there a reset procedure??
Thanks, Vinny
Old Oct 4, 2004 | 04:57 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
No reset procedure involved when i have gotten that message.
Is your oil pressure gauge working correctly on the dash?
I would also check to see if the computer is throwing any codes.
Old Oct 4, 2004 | 05:03 PM
Richin Chicago's Avatar
Richin Chicago
Thanks, Vinny
Keep monitoring your oil level to make sure. But when I got that code, after parking on a very steep hill, it took forever to get rid of the message. For some reason the computer wants to hang on to it. I finally got rid of it by disconnecting the battery cable.
Old Oct 4, 2004 | 07:36 PM
VinnyG's Avatar
VinnyG
Thanks Rich. I'll give the battery disconnect a try.......
Old Oct 4, 2004 | 07:50 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
If that doesn't work, it's time for a trip to the dealer
I got the "message" yesterday. I knew I was border line as I check at every fill up. But I'm doing an oil change tomorrow. Why pour a $5 quart of oil down the drain, right?
Well, I got the DIC message. Turned the car off, dumped a qt in, started the car.........
Message gone.
Keep us posted
Michael
Old Oct 4, 2004 | 08:00 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I've had the message pop up but after filling it disappeared also. Keep us posted.
Old Oct 4, 2004 | 09:56 PM
mfh4's Avatar
mfh4
Hey guys. I the exact same problem. I learned from the Chevy dealership that you have to let the car cool down for an hour or so and then the low oil level message will not come on again. I tried re-setting it just like you did and a mile or so down the road, it would come on again. Sure enough, when I turned the car off and started it up in the morning, the indicator did not come on again. There is no need to disconnect the battery as I think someone suggested.
MFH
To Low Oil Level
