LGM Pro Long Tubes Installed
Old Oct 8, 2004 | 05:26 PM
Mirek's Avatar
Mirek
I put mine in on jackstands. Took me a while but worth it.
I'll look for that monster around town. You may need a new 02 sensore assuming you moved your rears up front and ran simms in the back.
Old Oct 8, 2004 | 05:54 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
Default Update
I cleared the codes this morning and put 30 or so easy miles on it (wet roads). No check engine light. This included 4 individual start ups.
The LS1HowTo instructions mentioned a possible code just from the grease burning off from the inside of the pipes but that a few "spirited" runs should burn this grease off. I've already applied that possible fix :
We'll see! Thanx for all the help, Folks
Michael
Old Oct 8, 2004 | 06:23 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by WellAdjusted
I didn't want to blow my own horn. As a non-mechanic non-gearhead type going in, I relied on LS1HowTo.com and my ability to learn as I go. I read and reread the play/by/play upwards of 20 times over the last month. I felt like I'd done the install many times before I called the shop to reserve the lift.
But I won't pull any punches and say that I was completely confident going in. It was nerve wracking from the onset. I logged 15 hours on the lift thanx to the bolt-break-setback.
The only thing more gratifying than the new singing voice of my car is the fact that I've got, I've counted, 27 knicks and cuts on my still grease stained hands.
The curve ball with the broken bolt was NOT funny at the time. But I learned even more through it.
So it's all good
Michael
Great job Nothing more gratifying than DIY. Sounds like you had a pretty good time and are happy with the results.
Old Oct 8, 2004 | 08:19 PM
WellAdjusted
Cruise-In V Veteran
I learned more about this car in the last 3 days than I did in the first 1.5yr
And I just received high thumbs up approval from the SO on the results
She can't wait to drive it now
Old Oct 8, 2004 | 10:20 PM
NOZ06's Avatar
NOZ06
Gettin' ready to do some kooks, myself. Can you post a sound-clip so I can get an idea what I'm in for? I have old neighbors. . .
Old Oct 8, 2004 | 10:58 PM
JimAgain's Avatar
JimAgain
Great job on the DIY!
I have LT's and love 'em. Have had one O2 sensor code. The code had no effect on performance and I promptly cleared the code.
I have found a great source for various grades of latex gloves to accomodate any knuckle bustin' DIY project. I was lucky not to have to put my C5 LT's in myself.
Big congrats
Old Oct 9, 2004 | 10:37 AM
01c5z06's Avatar
01c5z06
I put my own Dynatech's on and it was a great experience! Love the new found power and sound, also.
Old Oct 9, 2004 | 02:44 PM
WellAdjusted
Cruise-In V Veteran
If I can figure out a way to upload and host a sound or vid clip I'll post it in a separate thread.
Oh! And old people get up very early and sleep like rocks
But if you're concerned about being TOO loud, well, you're Kooks with cats should be manageable
Good Luck!
