Proper Tire Pressure EMT
Old Oct 8, 2004 | 09:05 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default Proper Tire Pressure EMT
The other morning I got up and the car gave me a warning that my left front and rear tire were both low. Of course it was cold outside and the warning went away right after I drove.
I was wondering what the correct air pressure was and also if people are running at that air pressure or running a little higher or lower?
Old Oct 8, 2004 | 09:13 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
always follow what the tag on the inside of the door shows
30psi cold is where you should be
Old Oct 8, 2004 | 09:14 AM
C5 4 ME's Avatar
C5 4 ME
I agree
Old Oct 8, 2004 | 01:10 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Originally Posted by C5 4 ME
I agree
Me 2
Old Oct 8, 2004 | 01:18 PM
2K4Vert's Avatar
2K4Vert
I find that my readout displays about 1psi less for each tire than my pocket tire pressure tool. Is this normal? Which one should I trust?
Old Oct 8, 2004 | 01:51 PM
Wicked Weasel
I would trust your pocket one over the readout....
Old Oct 8, 2004 | 01:57 PM
JC in XTC5's Avatar
JC in XTC5
As per door, 30 PSI cold is the norm. I'll run maybe -1 PSI on the rear. DIC warning comes on at 25 PSI which is way too low even in cold weather. Every 10 degree temp drop will typically give 1 PSI drop.
Old Oct 8, 2004 | 02:16 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I would never worry too much about a 1 psi diffenence in a pocket gauge and the DIC. That's just not much difference, so whether 29 or 31 is not really that big a deal, IMO.
I would make sure the left and right sides have the same pressure (within reason) though, regardless of which method is used to check.
I've got a digital gauge from Radio Shack that reads in half-psi increments. Best I can tell, it matches the DIC readout.
Old Oct 8, 2004 | 02:44 PM
chasswartz's Avatar
chasswartz
I would trust the DIC reading
Old Oct 8, 2004 | 02:55 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
30 psi at 70 degree range as it get colder I add air since it drop about 1 psi for every 10 degrees. When filling the tire, I used my digital air pressure gauge but use the DIC info just as a guideline
Old Oct 8, 2004 | 02:56 PM
Tom/99's Avatar
Tom/99
I have been running 30 psi in the front tires, and 29 psi in the rears.
Old Oct 8, 2004 | 03:03 PM
gordonb50's Avatar
gordonb50
Me too ....
Old Oct 8, 2004 | 05:55 PM
Pressure should be 30 PSI cold - that is what is recommended on the driver's door sticker.
Old Oct 8, 2004 | 06:00 PM
NSTG8R's Avatar
NSTG8R
30 / 30 warm. 28/28 cold.
i was running 30F/32R .. but that's too much. it got bouncy.
Old Oct 8, 2004 | 06:02 PM
dyeggy's Avatar
dyeggy
St. Jude Donor '10-'11-'12, '14-'17,'21, '25
I find that if I keep it at 28 psi cold the pressure quickly gets up to about 35 psi depending on how late I am.http://forums.corvetteforum.com/newr...&p=1548473051#
Old Oct 8, 2004 | 06:53 PM
leaftye's Avatar
leaftye
I remember my tires pressures fluctuating by as much as 10 psi in the dead of winter from when I'd start it in the morning to when they fully warmed up on the way to work.
To Proper Tire Pressure EMT
