Stupid question here....
Old Oct 9, 2004 | 11:59 AM
MSD44's Avatar
MSD44
Default Stupid question here....
But what are the difference between an "X" pipe and a "H" pipe? Is it all sound, or are there HP gains ect?
Old Oct 9, 2004 | 12:35 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Not a stupid Q -
While I was at Andy's shop, I asked him the same question and he told me, on a stock exhaust, there's little to no effect. The X is supposed to reduce cabin resonance on the louder exhaust systems.
I still have my stock exhaust, so unless there is a benefit worth changing to an X, I'll keep my H.
Old Oct 9, 2004 | 12:44 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
an X pipe smooths out the exhaust "pulses" and delivers smoother flow resulting in less resonance...the crossover opening is much larger than the stock H pipe which on mine was no bigger around than a nickle!!
Old Oct 9, 2004 | 12:49 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The H-pipe has been designed into most factory duel exhaust systems to balance the left bank right bank exhaust pulse scaveging.,.. and equalizes back pressure. The H pipe design is a poor flow manager, but it's a cheap manufacturing application.. The X pipe on the other hand does a much more effecient job of balancing the exhaust pulses and will give better scavenging and reduce decell popping.. and add some ponies...because of better exhaust exit.
NSTG8R's Avatar
NSTG8R
no stupid questions here.
Old Oct 10, 2004 | 03:28 PM
MSD44's Avatar
MSD44
Thanks for the info.... Now I get it!!!
Old Oct 10, 2004 | 03:49 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Let's expand the questioning a bit...
I have a Borla Cat-back (Stinger w/duals) and kept the OEM H-pipe. I don't mind the popping, in fact I kind of like it, but I have been told by a "certified" GM Tech that it causes damage to the exhaust valves. Given that it may add some power, I'm now questioning swapping the H for an X. Is the H-pipe bolted in at both ends (I know that it is bolted aft because I bolted my Borlas to it, but is it also bolted at the forward end? Or is it welded in? (It's easier to ask you guys than to jack up the car and crawl under it.)
Old Oct 10, 2004 | 03:54 PM
NSTG8R's Avatar
NSTG8R
the H is bolted in ?
i think that's what you were asking.
Old Oct 10, 2004 | 06:22 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Everyone learns here every day. Good question there were some answers I haven't heard of.
Old Oct 10, 2004 | 06:24 PM
~SPEEDY~'s Avatar
~SPEEDY~
Old Oct 10, 2004 | 10:50 PM
mopac's Avatar
mopac
Default H-pipe bolted
I put on the Bassini X-pipe with the Borla after cat exhaust and the H-pipe is bolted in, while the pipe was disconnected i installed the heatmaxx shield in the tunnel, and that was worth every penny as the console was a lot cooler and then bolted in the X-pipe.
Old Oct 11, 2004 | 12:43 AM
STR's Avatar
STR
Cruising
what about a strait back exaust? I know its beneficial for huge turbo'd cars but what about these?
To Stupid question here....
