ACI front spoiler install
Old Oct 11, 2004 | 05:14 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Default ACI front spoiler install
Just got my ACI lower front spoiler back from the body shop after a shot of Electron Blue. There were no instructions included in the box for mounting.
Hopefully someone out there has done this and can give me some advice. I removed the old rubber spoilers on each side and the center spring loaded one.
I then attached the new spoiler at each end using the very first holes at each end. Apparently these are about the only original holes that line up. I then propped up the center of the spoiler to make it flush with the body.
I then marked all of the remaining holes to be drilled but I haven't drilled them yet as I need to get the front up on some ramps first to get enough clearance.
I figured out that the braces included with the spoiler (with the threaded thingies) needs to go up above the painted panel underneath with the screws going through the newly drilled holes and into the brace. I also figured out the small curved metal piece for the center of the spoiler.
What I need advice on is the correct way to get the metal braces into posistion and where to use the included pop rivets???
Any advice appreciated.
I promise to post pics when installed.
Old Oct 11, 2004 | 05:27 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
where did you get the spoiler and what did you pay???
also you need to leave the center air foil inplace or your car may overheat... this is what Ive been seeing from other with the same chin spoiler.. I am looking to doing this myself.. and IM collecting all the data I can..
Old Oct 11, 2004 | 06:52 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
If I remember right the rivets actually hold the metal brackets on and the bolts hold the spoiler to them.
Old Oct 11, 2004 | 07:30 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I have the four page Installation Instructions that came with my ACI front spoiler.
Send me your email address and I'll scan them tomorrow morning at work and send the instructiojns to you.
OR better yet, email me a fax number and I'll fax them to you Tuesday morning between 6 & 7am Eastern time
Old Oct 11, 2004 | 07:39 PM
2K14C7's Avatar
2K14C7
Thanks a bunch Glenn I'll take you up on that. You will have mail shortly.
Old Oct 11, 2004 | 08:09 PM
Sponge Vette's Avatar
Sponge Vette
Originally Posted by Evil-Twin
Also you need to leave the center air foil inplace or your car may overheat... this is what Ive been seeing from other with the same chin spoiler.. I am looking to doing this myself.. and IM collecting all the data I can..
Old Oct 11, 2004 | 08:11 PM
Glennm27's Avatar
Glennm27
Since you're doing it in Electron Blue, here are a couple previews for ya.
http://home.comcast.net/~glennm27/forum0704a.jpg
http://home.comcast.net/~glennm27/Corvette08070402.jpg
Old Oct 11, 2004 | 08:21 PM
Glennm27's Avatar
Glennm27
I got your mail and fax number. You'll have the Installation Instructions first thing Tuesday morning!
To ACI front spoiler install
