Keyless entry "sync"
Old Oct 13, 2004 | 06:24 AM
NJblackrose92's Avatar
NJblackrose92
Default Keyless entry "sync"
Has anyone found an easy way to re-sync the keyless entry FOBs on a C5? Just changed the batteries - I haven't read the manual yet (go figure), just not sure if there's an easy way to do this. Thanks in advance.
Old Oct 13, 2004 | 07:56 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The manual for my 97 says
"Try to resynchronize the transmitter by pressing and holding the LOCK and UNLOCK buttons for seven seconds when standing next to the vehicle." This will attempt to resynchronize the security code in your RFA key fob transmitter.
When resynchronization is achieved the horn will chirp. If attempts to resynchronize your transmitter to the vehicle are not successful, you man need to match the transmitter to the vehicle.
To match the transmitter to your vehicle:
1. Turn the ingnition key to the ON position
2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold the RESET button for two seconds.
4. When the message FOB TRAINING is displayed, push the RESET button once. The message HOLD LK+UNLK 1ST FOB will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned, the DIC will display FOB LEARNED and then prompt you to learn the next transmitter.
7. Repeat steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programmer mode will shut off if:
You don't program any transmitters for two minutes.
You take the key out of the ignition.
You have programmed three transmitters.
Hope this helps.
Paul
Old Oct 13, 2004 | 08:17 AM
NJblackrose92
Thanks for the response Paul - I'll give it a shot!
Old Oct 13, 2004 | 09:06 AM
Dave1998's Avatar
Dave1998
I followed these steps Sunday and worked fine !
To Keyless entry "sync"
