Shift woes
Luckly no apparent damage. But here is the thing. Many times I have trouble getting it into reverse without bumping it forward first. Also the shift feels sloppy and rough. Practicing in the driveway it seems awfull easy to miss 3rd and hit 1st. Question, is new shifter smoother, easier to get into reverse, and how about accurate shifting ie: 3rd to 1st?
It is a 03 AE and I am no stranger to shifting, but never had anything but a stock shifter. I DO NOT want to blow the engine because of a cheap shifter!
I think that you would probably benefit by getting a shifter with a shorter throw. My car had one already when I got it, so I really cant tell you what difference it makes. But I can tell you that I have not had any problems and I have raced mine too
oh, and the C6 has a short throw shifter from the factory. I havent driven one, but I am sure people that have will chime in on the difference between them and a C5 stock shifter.
Getting into reverse is easy if you put it in 3rd first. Go from 3rd to reverse and it'll go right in.
With a Hurst (I'm assuming all the other short-throw shifters as well), you'll get firm and precise shifts. I used the default springs in the Hurst (it has, IIRC, 3 sets of springs to choose from in the box) and adjusted them to be quite firm. If you slap the shifter from 2nd, it shoots over to the 3-4 position. Makes quick shifting a breeze. I haven't missed a shift yet since the install, knock wood. It pulls pretty hard to the center position, so you can tell exactly where it is and where it is going depending on which way the shifter pulls when you move it out of the gate.
In summary, I think the Hurst should have been factory eqiupment, especially on a FRC. I'm of the understanding that the Hurst can be almost as easy to shift as stock with the right springs and adjustments, but I like my shifting notchy so I know where it is. You'll probably like a short shifter, one of the best mods you can get for your MN6 Vette.
Sorny
This is a common problem with these cars and the Camaro/Firebird (T/As) with the six speed and you are correct if you miss a shift the momentum of the car will spin the engine over the redline very easily (take a look at the F-body sites some time). The revlimiter can do nothing at this point, it can shut off fuel or spark, but it is the momentum of the vehicle (through the drivetrain) that is spinning the engine.
A simple thing to do is your hand position. for the 2-3 shift, just push forward with the palm of your hand. Many people grab the shifter like a pistol with their thumb up, and the natural motion will tend to pull the shifter toward you....
Most common problem is bent pushrods, symptoms, tapping, rough idle and throwing some codes..
probably better that the pushrods bend rather than having pistons and valves come together...
I let my son and daughter drive it.
Dan
Just my 2 cents
DanThe most common is on the 3-4 gear change (grab 2 instead of 4). Usually done while racing, and usually not caught... engine usually goes 7000+,.... even for a few seconds can result in bent push rods...
Haven't seen that many posts on here, but there are usually a few on the F-body boards...
The stock shifter is pretty smooth, the problem is the gates on the six speed are fairly close togther... and the springs are fairly light (never know who will be driving).. So it is very easy to get the wrong gear.
As I mentioned in my first post, a lot off people always grab the shifter with their thumb up.... the natural motion of you arm is toward your....
One reason I prefer just a round ball shift ****.. (although I did love a T-handle on the hurst shifter on my old Muncie transmission)
For 2-3, just use your palm... for 3-4, thumb down and straight back (worst case with this is you would grab 6th)
Fortunately I have not done this.. but there have been a few on here and a lot on the F-body boards that have done it..
Do a search on bent pushrods... there may be some still in archieves...
info
Symptoms (genereally speaking).. rough idle, possibly a tapping noise (not to be confused with the piston slap at cold startup on some C5s), check engine light. There are a few other threads on pulling the covers and removing the pushrods to check if they are bent (rolling them over a flat surface, a glass plate works well)....
I have done this on some older cars, but not on the LS1...
If you bent a push rod you would know it..your engine will run rough and you will most likely throw a code.
I am really glad to see the posts about the rev limiter not having affect on mis-shifts..I thought it did...in fact I have missed a shift or 2 before and it bounced off the limiter..maybe I did not have the clutch released all the way and thought I did.
