Intakes: Any reliability issues associated with them?
Old Oct 13, 2004 | 02:49 PM
Zippy The Wonderdog's Avatar
Zippy The Wonderdog
Default Intakes: Any reliability issues associated with them?
I have been checking out the various intakes out there...and it seems that either the Blackwing or the Halltech Stinger is the way to go...and of these two the Stinger seems to be a bit more favored.
Are there any reliability issues associated with them? The reason I ask is that I know other cars, such as Nissan Maximas, have had problems with their MAF sensors failing as a result of aftermarket intakes.
On a side note...why not just do the zip-tie mod that I have read about? Uber-cheap way to go.
Thank you for your time.
Old Oct 13, 2004 | 03:02 PM
cuda's Avatar
cuda
I had the surging issue with my halltech after cleaning the filter. I switched to the blackwing. The blackwing looks stock, massive surface area, super easy install, far less water worries (although the halltech never had problems with water) and the surging issue never happens unless you start cutting holes int he radiator shroud. Blackwing was 225 and I am very happy with it. You want something cheap I will clean up the old halltech intake and sell it! Its an older model, tric.
Old Oct 13, 2004 | 03:03 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Haven't had one with Black Wing .. coming up on a year now.
Old Oct 13, 2004 | 03:05 PM
Thunder7's Avatar
Thunder7
Old Oct 13, 2004 | 03:15 PM
sharpvet03's Avatar
sharpvet03
Just ordered my Halltech Stinger from nate@corvette garage,will let you know when I get it in and installed.
Old Oct 13, 2004 | 03:17 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Just make sure that you don't over oil the filter because that could cause problems
Old Oct 13, 2004 | 03:36 PM
Dave68's Avatar
Dave68
The only issues I've heard of are lean codes generated by Z06s with aftermarket intake systems. These cars have no MAF screen, which smoothes out turbulent flow to the MAF wires.
I've had my Halltech Stinger-R since May, drive my car almost every work day, have performed my cold air induction mod, and have had no issues regarding drivability. This is truly the best bang for the buck out there.
Old Oct 13, 2004 | 04:21 PM
_Redline_'s Avatar
_Redline_
I've had my Halltech installed for a few days now. I must say so far I am very happy with it.
One small note, do not open your hood if you have any standing water on it. I did this morning and it dumped right on the air filter.
I would also recommend the hood seal. I did not install mine untill I had that.
To Intakes: Any reliability issues associated with them?
