RE:Speaker Size
Old Oct 14, 2004 | 10:01 PM
codeblue's Avatar
codeblue
Default RE:Need to know sizes on speakers front and back
I'm replacing speaker in my c5. I noticed they are 6 1/2 in the front, does anybody know what size is in the back? What brand works best for installation? I'm thinking about infinity's. What size do I order for fronts and what size do I order for backs?
Old Oct 14, 2004 | 10:08 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
3 1/2 tweeters, 8 inch subs front - 6 3/4 inch mids in the rear.
Old Oct 14, 2004 | 10:13 PM
codeblue's Avatar
codeblue
So tell me what size I put in the front and what size I put in the back.
Thanks,
Old Oct 14, 2004 | 10:29 PM
0EG@EnglandGreen
Supporting Tuner
Go to http://www.crutchfield.com and register your car (01 Coupe or whatever) - then select "What fits my car". There are other websites that have the same functionality, but this is the one I use.
The speaker choices are slim if you do not wish to mod your doors to accept different speakers.
If you remove the Bose/Delco head unit, the Bose subs in the doors stop working - so consider carefully if you wish to change your entire system or just change the front tweeters for a decent pair of mid/high speakers and swap the mids in the rear - or if you are going to go hog wild and change everything.
I opted to dump the entire system and went kinda crazy - but that's my personal sonic choice.
I installed 3 1/2 inch Alpines mid/tweeters and Rockford Fosgate 8 inch subs in the doors (custom enclosures), RF 6 3/4 inch mids and RF tweeters in the rear and a 12 inch RF sub in a semi-custom enclosure in the "wheel well" in the rear. Topped off with a couple of amps, reams of wire, some crossovers, a cap, Sony MP3 head unit and 10disc MP3 changer and I was good to go.
But there is no need to be so extreme - the Bose system comes to life (kinda) with just a speaker swap (front tweeters and rear mids).
Your mileage may vary. My .02 cents.
To RE:Speaker Size
