painting calipers ?
Old Oct 18, 2004 | 04:52 PM
26sonic's Avatar
26sonic
Default painting calipers ?
anyone know of the best product to use to do this? what about the cleaning up the rotars?
Old Oct 18, 2004 | 04:57 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I've not done the mod myself (just bought Z06 calipers) but if you'll do a search there are several posts describing the process.
Have fun with it
Old Oct 18, 2004 | 05:06 PM
I used Folia Tec on mine (got it from Xtreme Motorsports). Been on there three years and still looks great. You could use the same thing on the rotor hubs, which is what I assume you mean for the rotors.
Old Oct 18, 2004 | 05:12 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Mark (30yeardream) does a great job with powder coating to match the OEM paint.
If you're into doing them yourself, Rustoleum Sunrise Red looks and lasts terrific. As with any paint job, it is only as good as the "cleaned" surface. Be sure to use denatured alcohol prior to painting.
Good luck!
Old Oct 18, 2004 | 06:08 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Rustoleum Sunrise Red looks great and lasts great too.
Old Oct 18, 2004 | 06:11 PM
mlupone's Avatar
mlupone
Do the Z06 calipers offer better performance than non-Z06?
Thanks!
Old Oct 18, 2004 | 06:13 PM
RamjetVette's Avatar
RamjetVette
I got a can of the Mag Red touch up spray from Ken Fitchner. Cleaned the calipers with brake cleaner. Had it over a year now and still looks great.
Old Oct 18, 2004 | 06:14 PM
jrose7004's Avatar
jrose7004
VHT from AutoZone, Clean with paint thinner and a wire brush!
Old Oct 18, 2004 | 06:15 PM
SNAKEKILLER!'s Avatar
SNAKEKILLER!
Default ZO6 calipers...
No difference....Same caliper....part number only different because of the color....
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
No, they're the same thing, just red.
Old Oct 18, 2004 | 06:17 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Thanks!
Z06 calipers are identical as yours, well almost, the only difference is they are red and yours are not. That IS the only difference.
If you're into doing them yourself, Rustoleum Sunshine Red looks and lasts terrific. As with any paint job, it is only as good as the "cleaned" surface. Be sure to use denatured alcohol prior to painting.
The Rustoleum way is the very least expensive way to do it and that Sunrise Red Gloss looks great! I used that myself 2½ years ago and they still look as good as when I did them.
The powder coating would be a really nice way to go but of course a little more expensive and a little bit more work.
Old Oct 18, 2004 | 06:35 PM
Elite Engineering
Supporting Vendor
St. jude Donor '14
Thanks!
Other than the color red, there is absolutely no difference between the Stock and Z06 calipers.
Old Oct 18, 2004 | 08:08 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Old Oct 19, 2004 | 12:10 AM
WantstobuyaVette's Avatar
WantstobuyaVette
How do you guys keep from painting the Corvette letters red?
Do you just put tape on it? Then you cant color in between the letters.
Old Oct 19, 2004 | 12:16 AM
EricT43's Avatar
EricT43
My dad used Rustoleum on his '99, and he said the paint scraped off the letters easily with a sharp razor. Apparently it didn't stick very well to the machined areas...
Old Oct 19, 2004 | 12:45 AM
WantstobuyaVette
intresting...whats everyone else do for the letters?
Old Oct 19, 2004 | 12:48 AM
Xlr8tnC5's Avatar
Xlr8tnC5
I used the G2 System, Red. Easy to do with a brush on application.
To painting calipers ?
Old Oct 19, 2004 | 01:04 AM
vertC6's Avatar
vertC6
And old paint trick is wipe a little vasiline on the letters then wipe off after painting. The paint won't stick
Old Oct 19, 2004 | 01:33 AM
WantstobuyaVette
another good idea...hmmm
Old Oct 19, 2004 | 01:37 AM
jonjon's Avatar
jonjon
Very fine (1000 grit) sandpaper. Just let the paint dry then it comes right off of the letters
