[Z06] Big brake kits
Old Oct 19, 2004 | 04:48 PM
blown06's Avatar
blown06
Cruising
Default Big brake kits
What is the biggest front and rear brake kits available for a C5? And who manufactures them? Any bigger than Brembo's 355mm?
Old Oct 19, 2004 | 06:48 PM
AU N EGL's Avatar
AU N EGL
a 355 mm rotor is about 14" , which needs an 18" wheel to fit under.
Yes there are several manufactures and marketers of 'big' brake kits.
Brembo
Wilwood
Stoptech
AP Racing
Performance Friction
The last three are primaly road racing brakes with Brembo and Wilwood making both street and racing brakes.
Brembo on the Caddie CTSv
AP Racing
The pics above are from Grand-AM race cars
Old Oct 19, 2004 | 06:56 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
At this point I would either choose the Brembo or the stoptech units. If you like good wheels and tires to go with a setup like that get ready to spend $15K on the brakes, Custom built street tires and wheels as well as race tires and wheels. (dont ask me how I know about this)
VR
Old Oct 19, 2004 | 07:52 PM
trumper Z06's Avatar
trumper Z06
Both Grass Roots Motor Sports ( this month's issue) and Corvette Fever ( couple of months ago) have published feature articles on Wilwood big brake kits for the C-5 Vette. David Farmer also reps Stop-tech and recomends them highly.
You might want to check out both Companies Big Brake Kits!
Old Oct 19, 2004 | 09:52 PM
barondw's Avatar
barondw
Notice that on the pictures the rotors aren't drilled. Drilling encourages cracking. The Brembo and ATP rotors are dimpled.
Old Oct 20, 2004 | 06:00 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by barondw
Notice that on the pictures the rotors aren't drilled. Drilling encourages cracking. The Brembo and AP rotors are dimpled.
That is correct. These rotors are called "J" rotors. The "J" dimple helps remove debris and or brake dust from the pad.
Even the porsches that normally come with rotors with holes in, cast in, NOT drilled, did not have rotors with holes in. Most race series regulations do not allow rotors with holes, as even the bigger 1.4 in rotor ( normal is 1.25" ) as crack very quickly and risk of brake failure is very high.
Also remeber these are race cars and the rotors are replaced before each event too.
Old Oct 20, 2004 | 01:53 PM
barondw's Avatar
barondw
Drilled rotors are for show not go. Also if you are serious about replacing your brakes the fronts should be larger than the rears. There is little reason to have the rears the same size unless its for show, meaning symmetry.
To Big brake kits
