Dusty Motor
Old Oct 20, 2004 | 04:54 PM
Aggie99's Avatar
Aggie99
Default Dusty Motor
Hey guys,
Any recommendations on cleaning up the engine?
Old Oct 20, 2004 | 04:57 PM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
i'm sure others will have excellent advice on engine cleanup, but a hood seal will help keep the engine compartment from getting as dusty. just my .02
Old Oct 20, 2004 | 05:00 PM
GOZ2FST's Avatar
GOZ2FST
I got this from the Forum - and it works so well people will think you spent hours on it - but it only takes minutes.
Warm the engine up a bit - not HOT, just good and warm - then shut it off.
Liberally spray Windex on the surfaces - really soak it - avoiding the electrical stuff.
Close hood for about 10 minutes or so and let it cook a bit.
Rinse off Windex with a garden hose - don't soak it, just a good spray will get rid off all the junk on your engine. Again - avoid electrical stuff.
At this point I then mop up the water.
Then spray inside with Armorall - this time avoid the belts and pullys.
Close hood and let cook some more.
Open hood and clean up any excess.
My car at 70k+ miles looks showroom new under the hood.
Good luck.
Old Oct 20, 2004 | 05:05 PM
A gentle application of water will usually rinse all the dust off. Just be sure to avoid all those electrical connectors.
Old Oct 20, 2004 | 05:27 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Good luck.
I asked the same question a few months back and GOZ2FST gave me the same answer. I tried it and it worked very well. You'll still need to get your bottle of windex and squirt a few problem areas and clean them with a rag, but overall, it worked very well.
Old Oct 20, 2004 | 05:35 PM
QS-ZO6's Avatar
QS-ZO6
Default Dusty motor
Originally Posted by Aggie99
Hey guys,
Aggie,
First, get out of college station and drive to Austin, way less dust on the roads!! Seriously, I understand everones hesitance to go up to the local car wash and use high pressure, but if it is done carfully and correctly you'll be ok. Use the pre-soak (it's usually hot water) spray that on a luke warm motor - NOT HOT -. Then take the high pressure soap and rinse everthing off, switching to plain rinse water. I would try not to spray water into the open area of the alternator, but the connectors are all GM weather pack connectors. If you un plug your hood light, plug it back in - you dont want any open electrical plugs. Rinse everything else off and dry accordingly. I would also try not to use Armorall as this is the universal dust magnet. My 2 pennies -
Old Oct 20, 2004 | 07:14 PM
3318C5's Avatar
3318C5
I have also used Simple Green(The biodegadable one) it is very gentle, cleans like crazy, and will not eat thru your hoses!!!
Old Oct 20, 2004 | 07:31 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
To End Dust, use endust
My car is over five years old and has 55,000 miles on it.. my car has never seen any water.... this picture was taken a week ago..
Old Oct 20, 2004 | 07:39 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Spray it off with your garden house and then spray tire FOAM all over. Close your hood and let it dry for awhile. Then wipe down the motor with a rag. Kaley
Old Oct 20, 2004 | 08:18 PM
USA-VET's Avatar
USA-VET
also don't get your Opti-Spark wet!
Old Oct 20, 2004 | 08:20 PM
jrose7004's Avatar
jrose7004
A bucket of water, a rag and a shammy will work!
Old Oct 20, 2004 | 10:57 PM
BHP's Avatar
BHP
No hose! Just wipe with a moist rag.
Old Oct 20, 2004 | 11:10 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Hey E-T, are you serious or just joking as usual. I've thought about using it instead of Armorall and wondered if it would work.
Old Oct 20, 2004 | 11:30 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I have heard of the anti-knock sensors corroding due to people washing the engine compartment. If you do wash it make sure you go for a good run afterwords to make sure no water is left in there. I simply use my compressor and blow out most of the crap. And surprisingly it get 80-90% of it. I then use old terry towels and clean the rest of it. Since I got the hood seal not much gets dirty in there. Not like before I had the seal installed. There's my .02 Hope it helps.
Old Oct 20, 2004 | 11:34 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I use my shop vacuum to vacuum all the grit and dust under my hood. Try it ! It works great but I would not use it if you have leaking gas in any part of your engine compartment.
Old Oct 21, 2004 | 12:35 AM
Old Timer's Avatar
Old Timer
I'm suprised that no one has mentioned this method. If your engine is not excessively greasy/oily (never happen on a vette, right) a leaf blower will work miracles on dirt and dust under your hood. In addition, it's blindingly quick and thorough. It will get dirt you didn't even know was there. Of course be careful near the painted surfaces of your front fenders. (not a real problem though) Just remember, wet electronics can mean big bucks!
Old Oct 21, 2004 | 01:11 AM
NSTG8R's Avatar
NSTG8R
there's a good idea ... especially here in florida, spray down your engine with water that way the engine & all the nuts and bolts that keep it together will corrode nicely.
also, i've heard of water leaking in through the intake and hydolocking the car. So be careful with whatever you do and the word of the day will be moderation.
To Dusty Motor
Old Oct 21, 2004 | 03:28 AM
jdmvette's Avatar
jdmvette
Night Owl for life
I use my air compressor to get every last nook and cranny dust free. It also comes in handy when drying the car around those hard to dry places such as the mirrors, emblems and the center cap lug nut area.
Old Oct 21, 2004 | 05:15 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Works great and no water problems...
Old Oct 21, 2004 | 06:13 AM
C5naples's Avatar
C5naples
My motor was a dirty mess when I got the car , I did not want to use water so I used an air compressor to blow the dirt out and a lot of damp rags to clean it up a bit.
