kooks install how to's?......
Old Oct 21, 2004 | 02:35 AM
SPD KILZ's Avatar
SPD KILZ
Default kooks install how to's?......
Does anyone know of a kooks specific how to? Or did you guys just use the one for LG's on ls1howto?
Old Oct 21, 2004 | 08:34 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
http://forums.corvetteforum.com/show...2&page=1&pp=20
These others below are a bit old and before the revision to the driver side header. One poster was used rubber mallet. This is NOT necessary.
It is also only necessary to disconnect the steering linkage at it's lowest point and move it aside. No need to remove the entire shaft. When you get the car on ramps be sure that the front wheels are dead straight and you allow the steering column to lock when you switch the car off.
http://www.jakelatham.com/C5/projects/kooks/
http://www.z06vette.com/forums/showthread.php?t=58992
http://www.z06vette.com/forums/showt...=kooks+install
Old Oct 21, 2004 | 07:44 PM
SPD KILZ's Avatar
SPD KILZ
thanks for the info..... anyone else have something to add?
Old Oct 25, 2004 | 12:14 AM
SPD KILZ's Avatar
SPD KILZ
ttt
To kooks install how to's?......
