Storage ?s
Old Oct 21, 2004 | 12:05 PM
kuip64's Avatar
kuip64
Default Storage ?s
Can anyone tell me, what are the critical steps to storage of a C5 coupe. Anything special I need to know. I will be keeping it inside on cement with a cover but the building is not heated.
Old Oct 21, 2004 | 12:36 PM
SavPrato's Avatar
SavPrato
May I suggest the following for a start;
use a battery tender
change your oil and go through one heat cycle (min.)
increase tire pressure to 40 PSI
close openings from rodents (if applicable)
fill tank with fuel, add stablizer
just a few ideas
Old Oct 21, 2004 | 12:44 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
one other thing I would do is put some di-electric grease on the weatherstripping.
Old Oct 21, 2004 | 10:23 PM
ROJ#79's Avatar
ROJ#79
Sheet of plastic on the floor under the car also works well to keep the moisture and dampness away from the vehicle.
Old Oct 22, 2004 | 02:19 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
This works best
To Storage ?s
