Headlight issue
Old Oct 21, 2004 | 03:08 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Headlight issue
I posted on tech but so far no one has come up with an answer. My headlights won't pop up. The lights come on but the doors don't open. They opened this morning and then after a stop, when I went to turn on the lights the doors stayed closed. After I cycled the switch they came back on. When I got to work I turned them off and then back on and nothing. Bulbs lit but doors stayed down. I cycled the switch a few more times and nothing. At lunch I went out and tried again and they went up and down several times without fail. There is no motor noise. After I drove the car for a few minutes, I tried it again and the doors did not open. Do I have a sticky relay/module and where is it located? The car is a 98 vert. Thanks.
Old Oct 21, 2004 | 04:24 PM
mike1944's Avatar
mike1944
One of the drivers reported this problem, was fixed by tightening up the battery terminal connections. Same thing was causing my radio lights to flicker. Good luck.
Old Oct 21, 2004 | 07:46 PM
Tally Ho's Avatar
Tally Ho
I suspected a problem with my battery connections today. I'll try it. Thanks.
Yep. Found the positive terminal corroded. Cleaned her up and all is well. I guess with the moisture 4 hurricanes and a tropical storm the last few months, this was bound to happen. Thanks again for the suggestion.
Old Oct 21, 2004 | 10:37 PM
mike1944's Avatar
mike1944
This forum is great. Glad it worked.
To Headlight issue
