As I understand it, the good stuff that 3M makes is controlled through dealers. The dealers have rolls of the material, and when you purchase a package the dealer downloads a single cut from 3M or whoever controls the patterns, and feeds the info to a cutter/plotters which cuts the custom pattern (one at a time). at least that is how it was explained to me by a dealer. It is really good stuff and even lays on well over the Z16 stripes.
There are a few down falls with the 3M as there is with any product. I have a black car so I can see those down falls where others may not. The material over time does get swirl marks just like the vert's paint. I had some problems finding someone to install mine. I had to have a guy come down out of Ohio. Then a bad storm kicked up while he was installing it and a little bit of debris go under it here and there. (this was before I had a garage) There is one spot on the nose near the badge that the guy had problems getting the product stretched over the badge. I think he stretched it a little too much and it created a orange peel look. I can live with one spot of a little orange peel over BAD stone chips. Since I purchased mine the design near the badge has been improved so not as much stretching is needed. I'm still glad I got the product.
Good luck!!
Good luck!!
The dealer that did mine talked about the problems with debris or even lint that can get under the film. Says that it can take lots of time to relift the film and get the debris out. Finding a dealer that cares and will take the time is vital. After watching part of the process, I can't imagine doing it myself and expecting perfection. I have seen a couple of cars that have had the film on for a couple of years with lots of miles and it is amazing how well the film works.
3M invisible bra is the way to go, great product, great protection! For best results, make sure you have it installed by a professional installer. I saw the guy putting the film on my car, he was able to install it without relifting the film and the installation is flawless.
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
My DIY job turned out perfect. I wetted the floor of the garage before I started and have no lint or other crap under it. My kit was made with a cutout around the hood emblem. I can't imagine stretching it over that.
For the 3M stuff, what do you ask for when you go to the parts counter besides "the 3M stuff" I'd like to go buy and pick some up.
Its "3m's Paint Protection film". But it doesn't come pre-cut that I'm aware
of. The shop I had my windows tinted offers the paint film. I have it on
the front end, behind each wheel and rocker panels. The only draw back
is if you have a darker colored car and get wax at the seam, the seam
shows. Heres pics of mine;
My 00 coupe is black and the seams would probably show up in an instant. However I think seams are better than chips so I may go ahead and risk it.
Thanks for the pics
Hey!!
Your seams will show a little but not real bad. You just have to "learn" how to wax the car with the 3M on it. Apply and remove the wax rubbing it away from the seems. I have gotten good at it now.
