Jacking car
Old Oct 21, 2004 | 04:20 PM
Ward1's Avatar
Ward1
Default Jacking car
does anyone know how low a racing jack has to be to fit under the front of a C5 without driving up those little ramps?
Old Oct 21, 2004 | 10:19 PM
ROJ#79's Avatar
ROJ#79
I just bought one of those Alum. Racing jacks at a flea market. It's plenty low enough but the problem with jacking the front up is that the handle does not go down far enough. When you stick the jack in behind the front wheel to lift on the front cross frame. The handle hits on the rocker panel.
So I have to use my old NAPA Jack because the handle on that one goes all the way down. Other wise the Jack works great. Most all I have seen, have the same profile.
Old Oct 22, 2004 | 05:39 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Both Sears and Harbor Tools have aluminum racing jacks for about $130 that will clear. Do NOT buy the cheapie. It won't hold (or so I've been told).
http://order.harborfreight.com/EasyA...ht/results.jsp
Old Oct 22, 2004 | 09:40 AM
Thunder7's Avatar
Thunder7
I have the Harbor Freight one, and it works GREAT!!
Old Oct 22, 2004 | 05:22 PM
RCK1999's Avatar
RCK1999
Get (or make) some jacking pucks. Use these along with your jack to lift from the frame rails (not the cross-frame).
To Jacking car
