Twist Tie Method ?? QUESTION
Old Oct 21, 2004 | 07:10 PM
UpToVT's Avatar
UpToVT
Default Twist Tie Method ?? QUESTION
My old man asked a good question.......
Isnt the stock air filter paper and wont it just fall apart when it rains ????
I know, I know, this is the cheap way out at the moment.... But my metal straps kept falling off and I remembered reading about it.
Will a K&N be better than the stock paper ??
Or will the 250 blackwing or varam be better worth the cost.
All I have is a 4 tip Borla Stinger on my stock vette.
Old Oct 21, 2004 | 07:26 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
you could get the performance seal that closes off the front part of the hood and helps keep the water out.
I would recomment buying something like a Halltech (look for a group purchase) or another brand just because they are designed for what you are trying to accomplish.
I have the Halltech and it took about 1.0 hours to install taking my time. The hard part was removing the original filter, but even that was easy.
Old Oct 21, 2004 | 07:48 PM
UpToVT's Avatar
UpToVT
I appreciate the post...
So I should put back the outside of the box back on...???
Old Oct 21, 2004 | 08:03 PM
Larry_Yerton's Avatar
Larry_Yerton
Here's a couple pics of mine with the K & N before I got the blackwing.
UpToVT's Avatar
UpToVT
Old Oct 22, 2004 | 09:21 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Could get a Z06 airbox cover (bigger opening) for about $35 to put on or take your stock one and do the 'swiss-cheese' mod by cutting some openings in it.
Old Oct 22, 2004 | 01:37 PM
If you get the hood seal, the water should not get into the filter area.
I went with the Blackwing, mostly for increased air flow but also for looks. The Halltech Stinger will do the same thing as the Blackwing.
Old Oct 22, 2004 | 02:07 PM
QS-ZO6's Avatar
QS-ZO6
Default Cool Breeze
We have the Blackwing for $229, but the best system on the market would be the MTI true ram air system, $349. The ram air system grabs cold air from outside the car. Give me a call, 281-870-8787 with any questions.
Chris S.
To Twist Tie Method ?? QUESTION
